presets in protools wrong behavior
bought a new mac and it comes and only can run mojave 10.14.5,
im still in pro tools 12.7.1 and I was going to update until I saw what avid decided to do in july 1 so... ill stay in 12 until I find another girl for me... anyone found a workaround for presets nor working as expected? when pressing plus and minus buttons in protools they just go wherever they want... a real pain in the arse to be sincere. Last edited by EdwardG; 07-03-2019 at 06:14 AM. |
Re: presets in protools wrong behavior
Expected, I expected everything... that's why I'm not arguing about it and searching for fixes or workarounds.
anyway what I meant was, that in pro tools the plus and minus buttons used to circle through presets don't work in the expected manner and they just jump from preset to preset in a weird behavior... not following the numeral or alphabetical order. I found the answer as to why it does so and it is because of the APFS sistem file that my new mac comes with. so as my version of pro tools is not prepared for this file system, this is how is gonna be for now... cheers |
Also you didn't explain a lot about your issue .
Mac M1 Studio Ultra - Sonoma Beta OS Avid Carbon Interface Protools Ultimate |
As an example of running a non-compatible combo of PT and OSX - I'm running PT 11.3.2 on Sierra OSX 10.12.6. No way according to the compatibility chart should that work but it does. There's one well known hiccup and that's that to import audio you have to do drag & drop from Finder and not via the import audio menu command. When you do such things you have to be aware that there will be issues and how to deal with them if one can. But being the op is on Mojave his only remedy is to upgrade to PT 2019.5 (6). |
Exactly !
that was rude m8, seems like you don't/can't understand me, don't blame you its a very weird thing to happen actually, Ive already explained it very nicely but there we go again with a more detailed explanation. when you open any plugin, what you see is that there's is a PRESET ''section'' above the plugin itself, in that section there is a ''preset name'' box that you can click and it ''pops out'' a LIST. Below that ''box'' there is a PLUS AND MINOR buttons. well, because APFS in mac os x returns information in form of hash weight instead of numeric or alphabetic, my version of protools cant work with this kind of data, instead of going from preset 01 to preset 02 when clicking the plus button, what it does is jump to another preset like 43 etc. I suppose the current version of protools is designed to work with APFS and thats ok, but that is not a fix for me, after 15 years working with Pro tools I'm fed with avid so no, Im not giving them any of my money anymore. when I find a system that works perfectly I maintain it for as long as I can, I do orchestral work now and needed a 64 ram 18 core mac, so yep... time to meddle in things like described. And yes I fixed it by going back to HFS, now presets work as intended etc when I find me some time Im thinking of going full time DP and also look into logic (thou maybe im too old to learn another daw from scratch) anyway after many test all its rock solid and perfectly working thank you for your time, and my apologies if the way I express myself looks that bad, I feel very sorry that my English was that utterly useless to you, have a nice one. |
As for going to DP - unless you're masochistic don't do it. I picked up DP when Avid started the subscription business way back when. Was that ever a mistake. They don't have true instrument tracks like PT has. The fonts used are really small. The consolidated window is a cluttered mess. I made the mention of using an online translation program because you were not explaining yourself clearly as to what exactly you were referring to. |
Wrong behavior for EQ section on D-Control | Gregor B. | ICON & C|24 | 1 | 04-15-2015 05:10 PM |
So ProTools is mathmatically wrong. | Matt Whritenour | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-22-2005 05:25 PM |
Protools Plugin Presets... | Fladlien | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-12-2005 03:58 PM |
odd relinking behavior -- linking the wrong files | sndgeek | Pro Tools TDM Systems (Mac) | 0 | 11-22-2004 06:41 PM |
ProTools strange behavior | Kam Lion | Pro Tools TDM Systems (Mac) | 1 | 11-23-1999 12:24 AM |
