Old 03-18-2018, 10:49 AM
APDy APDy is offline
Default How to contact AVID SUPPORT ?
I can't connect my artist mix. It seems in the eucon settings that I can't attach it 8but the surface is listed). How can I get support from Avid. Do you have to pay the support to have their things work ? really ?
Old 03-18-2018, 05:49 PM
EddieJones's Avatar
Default Re: How to contact AVID SUPPORT ?
No you don't have to pay for support...thats what this site is for but if you do want 1:1 support head over to here: Audio Support
Can you tell me a little bit about your setup?
Operating System, EUCON version, DAW version and how you are connecting the Mix to your Computer ?
Old 03-19-2018, 01:15 AM
Thanks for the reply.
I have the following setup:
artist mix
Macbook pro with OSx 10.13.1
Daw: Reaper 5.77
eucon v4.0.3*138
I have downloaded the patch to make it work with reaper and it use to work fine. I think I have a problem with the router/ethernet adress. Here is attached a copy of my screen.
Thanks
Old 03-19-2018, 06:36 AM
EddieJones's Avatar
Do you have the MIDI ports setup in the EUCON Control Panel and Reaper ?
Old 03-19-2018, 02:01 PM
yes, the artist mix show up in the midi ports. I have attached pics here.
https://postimg.org/image/g68ywvajp/
https://s26.postimg.org/6lpca1ay1/Ca...a_21.58.41.png
Am I suppose to be able to attach a workstation ? because when I click on attach, nothing happens.
https://postimg.org/image/b8veb9nut/
Old 03-19-2018, 03:39 PM
EddieJones's Avatar
The beauty of pictures...The first thing I see is the Enable external Workstations is checked and shouldn't.
I would do this, make sure you have the very latest build 18.3.0.244 Run it and check the uninstall everything and the uninstall user prefs setting. Reboot and run it again and only install EuControl. Setup the MIDI ports again the EUCON Prefs panel.
Old 03-20-2018, 03:11 PM
Thanks ! Finally works with the latest software 18.3...(not so easy to find though ...). I needed to check the install of the artist mix and not the eucon, but it finally worked
Old 03-20-2018, 03:35 PM
MoPro's Avatar
MoPro MoPro is offline
artist mix
Daw: Reaper 5.77
eucon v4.0.3*138
Thanks
Hi APDy, I don't know if you know this, but there is a EuCon Adapter in development for Reaper, so no need for a MIDI connection for the Artist Mix to work.
You might want to read-up on it on the Reaper forum, if you haven't already done so.
https://forum.cockos.com/showthread....122509&page=16
Computer Asus P9X79 Deluxe | Intel i7 3930k | 32 Gig Ram | Intel 520 SSD's | 2T Caviar Black
Software Win 7 Ultimate (64bit) | Cubase Pro 9.5.41 (64bit) | WaveLab 9.5.25 (64bit) | HALion 6 (64bit)
Hardware RME FireFace's UFX / 800 | MOTU MTP AV USB | Avid Artist Series: Control, Mix, and Transport | EuControl ver. 18.3
do you have to pay to contact avid support? R3D3 Pro Tools 10 4 10-10-2012 07:12 AM
Is there a contact support form for Avid I don't have to pay for? Imran5000 Windows 0 07-03-2012 11:52 AM
Imposible contact avid support for RA # waranty POLY JR General Discussion 0 01-16-2012 11:11 AM
How to contact Avid PT Support? thelead Pro Tools 10 2 10-28-2011 01:13 PM
