Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
Old 08-14-2019, 03:35 PM
ouchmypockets ouchmypockets is offline
Default Clicking "Add MP3" adds ~1min of silence to the end of the file
If I am bouncing a WAV and I click "Add MP3" then the exported MP3 has ~1min of silence tacked on to the END of the file, while the WAV remains the correct length. So for example, if the project is 7m15s long and I Bounce To Disk, select WAV, and click the "Add MP3" box to the right, on export the progress bar will actually read "x:xx/8:15" and the WAV will be 7:15 long while the MP3 will be 8:15. However, if I export only to MP3 then that MP3 will be 7:15 long. It doesn't matter if the file(s) or project are 3min or 120min that exported MP3 always has almost exactly 1 extra minute of silence at the end (and the WAV does not).
We have found this issue to be office-wide, all of us operating the same version of PT and using roughly similar OS.
Is this a bug or have we inadvertently checked/unchecked some unknown box somewhere?
Old 08-14-2019, 03:47 PM
Sardi Sardi is offline
Default Re: Clicking "Add MP3" adds ~1min of silence to the end of the file
This has come up a fair few time on the DUC. Fairly recently as well IIRC.
I can’t remember if it was a bug or an incorrect setting, but if you search the forum you’ll find a few threads discussing the issue and hopefully a remedy to your situation.
Old 08-14-2019, 04:12 PM
Maybe I'm not using the correct keywords but I could not locate anything specific to this kind of silence so I decided to post here for help. Any suggestions for how to search even would be helpful! Thanks in advance!
Deleting unused files, is there a more efficient way than clicking "Yes" 300 times? tj7 Pro Tools 10 3 04-26-2014 08:25 PM
Save as > "Could not 14404 because File or folder not found (-43) while opening "..." Elias Stiza 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-10-2012 07:06 PM
"unable to parse audio file" and "OSStatus Error -208" ! reichman Post - Surround - Video 2 03-22-2010 04:46 AM
MP3 Option adds silence to start of file groovy tunes 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-29-2003 06:33 PM
HOW can you import a "stereo" WAV. file into PT as a "mono" file? peter parker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-21-2002 09:14 PM
