Old 02-13-2014, 04:15 PM
arturocivit arturocivit is offline
Default Eleven Rack and Behringer BTR2000 Connection?
Hi guys, I have a question related to the BTR2000 rack tuner, maybe someone here works with that unit and can give me a hand, basically the thing is, I have a space rack with:
Power
BTR2000
Eleven Rack
Then, using as amp a V-Tone GMX210, the way I'm connecting the Eleven Rack to the amp is like this:
11R Output to Amp 1 to Amp Slave In Left
11R Output to Amp 2 to Amp Slave In Right
This thing sounds amazing by the way!
Then, the problem I have is with the tuner, the way I connected the tuner is like this:
Guitar to Input on 11R - FX Loop Send (Left/Mono) to Input 1 on Tuner - Output Main from tuner to FX Loop Return (Left/Mono).
This will hook my tuner up to the FX Loop of the 11R so that when I activate the loop, the tuner gets the signal. But is not happening, when I activate the loop the BTR2000 is dead, nothing happens, if I connect the tuner directly to a guitar using the front input 1 then works like a charm, so, wondering if you guys have any advice about this?
Thanks!
Arturo
Behringer FCB1010 with Eleven Rack Kruegmeister Eleven Rack 11 12-13-2015 08:31 PM
Apogee Quartet & Eleven Rack Connection Becharax Eleven Rack 3 03-10-2014 10:10 AM
Eleven Rack & Benchmark DAC1 USb connection DeButte General Discussion 4 12-01-2011 02:19 PM
Eleven Rack Loosing Core Audio Connection Barry Johns Eleven Rack 3 09-23-2011 09:23 AM
Behringer FCB1010 Uno Eprom Sysex File For The Eleven Rack Benoni Eleven Rack 3 06-04-2011 06:17 PM
