Omni optical out....for 5.1 monitors..
Ive just picked up a logitech z5500 as a domestic type ref for 5.1.
Just wondering of its possible to use the Omni optical out to feed them. It has coax, and optical inputs, as well as analog ones... I dont think the Omni can output multichannel non Dolby signal as you cant assign the output to more than 2 channels |
Re: Omni optical out....for 5.1 monitors..
You can assign the Omni output to up to 8 channels. However, the only multichannel digital path is for AES.
To use optical out, you would need to set the Adat outputs to be just line outs, by setting the monitor path to "none". Which is fine, because your Logitech becomes your monitor control, rather than the Omni. But it's a little complex, and I'm still figuring out how to configure this in my Omni, as I want to try using the Adat outs into my home theater receiver. |
thanks for your post. I'll try that....I have a feeling that the z5500 digital inputs only look for dolby flavours though....
I do have a 192 on my system too though |
The 192 will actually be easier to configure in this situation.
Looking at the z5500 manual, it looks like it may accept straight digital signals. But if it's only Dolby, you would need something like the Neyrinck plugins to encode it first. |
I'll try a few things out and post back....I need to be a bit careful with what I end up doing as this is my secondary / alt system. Still not bought the main 5.1 monitors as yet.
it's possible that the adat and your optical on the logitech might not work, in this case the logitech is looking for ac3 over lightpipe and adat has never been that. adat is descrete 8 channels over lightpipe.
often consumer lightpipe isn't discrete.
NuanceTone.com |
Trim Optical Inputs on OMNI? | dwaynedelario | Pro Tools HDX & HD Native Systems (Mac) | 13 | 03-13-2013 01:34 PM |
Switching between two sets of monitors on Omni ? | chrisdee | Pro Tools HDX & HD Native Systems (Win) | 13 | 08-12-2012 11:44 AM |
OMNI Fried? Calling Omni Members - Check High Samplerates | KingFish | Pro Tools TDM Systems (Mac) | 3 | 11-03-2011 09:19 PM |
Be aware! Potential HD Omni buyers with treated Rooms and Computers. Omni Noisy Fan | FRaNCo MuSiC | Pro Tools HDX & HD Native Systems (Win) | 0 | 09-25-2011 05:42 AM |
Omni with digital monitors? | Baguette | Pro Tools TDM Systems (Mac) | 3 | 12-05-2010 07:40 PM |
