Old 09-16-2013, 07:06 PM
Peter Baird's Avatar
Peter Baird Peter Baird is offline
Default Offline bounce offset
I installed 11.0.2 because of all the bug fixes and did my first show with it today. Everything is ducky except...
Anybody seen this?
My Session Start was 09:00:00:00 and I bounced a performance touch-up that happened in real time at 17:22:25;24. When the Avid editor opened the WAV file on his timeline the Original Time Stamp for the bounced file had been magically changed to 08:22:25;24.
Seems like Offline Bounce is subtracting the difference between Session Start and 00:00:00;00 and using that as the Original Time Stamp for the file.
Just checked, normal bounce does the same thing. I did this twice with 11.0.1 and the Original Time Stamp on the bounced file was correct.
Let me know if I'm doing something stupid, but I'm thinking the workaround for now is to leave Session Start as 00:00:00;00. Might be inconvenient, but I bet the Original Time Stamp will now be correct. Let you know tomorrow.
Peter
Gypsy: PT Ultimate 2019.5, 12-core Mac Pro 3.46Ghz 64GB OS 10.14.5, HD Native, HD OMNI, 2 Artist Mix, EUCON 18.3, Presonus 32R, Studio One 4.5.1, Quad Eight preamps, Neve 3201 EQs, 2 LA-4s, Malone Design Works desk
Laptop: 10.13.6 MacBook Pro 2.8 Core i7, 16G, PT 19.5 Live 9
www.remotewest.com
@RemoteWest
Old 09-17-2013, 05:29 PM
Default Re: Offline bounce offset
Okay, it's official. If I set the Session Start time back to 00:00:00;00, the Original Time Stamp on any bounced file is now accurate. Can't believe this isn't causing more head-scratching here in Pro Tools land. Doesn't anyone (other than humble self) use a Session Start time other than 00:00:00;00?
Hope they can fix this in a maintenance release.
Peter
www.remotewest.com
@RemoteWest
Old 09-17-2013, 05:47 PM
Craig F Craig F is offline
A) why are you using the drop frame instead of non drop frame timecode?
B) why are you starting at midnight all zeros instead of starting at 01:00:00:00?
C) what frame rate are you working at?
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 09-17-2013, 06:50 PM
Color television. (Sorry, couldn't resist.) All live-to-tape production that I know of uses drop frame to keep clock time roughly matched up with video time.
That's kind of the point. Unless my Session Start is set for 00:00:00;00 the time stamp that prints on a bounce is incorrect, offset by exactly the difference between whatever the Session Start may be and 00:00:00;00. In other words when I have a session start time of 09:00:00;00 the time stamp on any bounced file is offset -9 hours. Which didn't happen in 11.0.1, I think.
59.94. Normal broadcast 1080i HiDef.
Pretty sure this is a bug.
Peter
www.remotewest.com
@RemoteWest
Old 01-14-2014, 09:37 AM
Intersound Intersound is offline
Yep, I have the same issue here with ProTools 11.0.3.
If my sessions have a different session start time than 0:00:00:00 the offline bounces have an offset as described my Peter.
Pretty annoying I hope Avid solves that very fast in the next update.
Old 01-15-2014, 02:19 PM
Bump...no one having this kind of issue ? Any changes in ProTools 11.1. ?
Peter, did you solve that somehow ? Thanks, David
PT 11.3.1 HDX2 OSX 10.9.5
Mac Pro 2x2,66GHz 6 Core Xeon / 32GB RAM / D-Command
Offline bounce bug ? deardaddy Pro Tools 11 20 12-28-2016 02:43 PM
Offline Bounce maxsuperpower Pro Tools 11 20 12-09-2013 11:06 AM
offline bounce different than realtime bounce grant howarth Pro Tools 11 8 12-08-2013 09:29 PM
OK, but seriously, OFFLINE BOUNCE! Kris75 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 120 04-09-2013 06:55 AM
Offline bounce spyfly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-21-2007 12:50 PM
