Old 11-30-2005, 08:42 AM
uwehaas uwehaas is offline
Default mono check
Hi
does anyone knows, if there is a plug in to make the stereo sum mono or any other way to check mono, without using an
external mixer or monitor controller?
Old 11-30-2005, 09:17 AM
Roy Pahlman Roy Pahlman is offline
Default Re: mono check
Am I missing something? How about panning the stereo to center?
Old 11-30-2005, 10:10 AM
InjuredEar InjuredEar is offline
If you have the Waves bundle, try the S1 imager on your master fader and set it to mono. leave it in bypass except when you want to check mono compatibility.
Old 12-07-2005, 08:22 AM
As I use Logic as my main software, there is no possibility to center the left and right output......
Old 12-07-2005, 08:28 AM
thanks a lot for the S1 tip that a great help....
Why check your mix in mono? KevinAllen General Discussion 29 01-28-2010 01:15 AM
How can I Check my mix in Mono? Derekten 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-01-2008 01:57 AM
Check Mono....? danwillrock 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-19-2007 04:10 AM
how do I check my mono mix "in the box" Ben Davis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 01-21-2007 04:34 PM
Mono check on 001 Mac Shack 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-18-2005 08:36 PM
