#141
Re: Pro Tools 18.1 (12.9)
MacBook Pro: 16GB M1 Pro 8c Hackintosh: MacOS Catalina, i7 6700k, 32GB RAM, RX580 Pro Tools Studio, RME RayDAT PCIe http://www.liamgaughan.com |
#142
Overlapped clips create a new playlist.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
#143
I know that's the setting... I'm just saying, it seems dense to allow both. If i'm using the keyboard shortcut then maybe it shouldn't do it. But fiiiiinee I'll go click a single check box.
Pro Tools is done for. All these features and I still have to think a little bit
#144
Re: Pro Tools 2018.1 (12.9)
Which Mac OS are u guys running w/ 2018.1 and feel is most stable?
PT Ultimate 2023.06, Mac Studio Max M2 64GB RAM, HDX, OSX 13.04.01, EuControl 2023.06 w/ Avid S1 |
#145
High Sierra is working great here.
Retro 176 (pair), Pultec EQP-1A (pair), Germanium Comps (pair), BAE 10DC (pair), Distressor (pair), Manley Vari-Mu, Sta-Level, Zener, SSL Fusion, SSL FX G384, API 2500, LA2A, 1176, Bricasti, Massive Passive, Anamod ATS-1, Eventide H3500, TC 2290, Yamaha D5000, PCM92, PCM70... Amps, Amps & More Amps. |
#146
Great to hear. Are you on the latest version of it? 10.13.3 ?
#147
Just downloaded and installed it. Opened and played a couple of sessions I’ve been working on and all seemed to be fine. Tried the EQ curve display and it seemed cool, but no game changer. That said, I’ve been darn happy with 12.8.3.
__________________ Al Hospers bassist, vocal, composer, engineer https://www.youtube.com/channel/UCCw...ogfR_7Q/videos ------------------------------------------------------ PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones... |
#148
10.13.3
Retro 176 (pair), Pultec EQP-1A (pair), Germanium Comps (pair), BAE 10DC (pair), Distressor (pair), Manley Vari-Mu, Sta-Level, Zener, SSL Fusion, SSL FX G384, API 2500, LA2A, 1176, Bricasti, Massive Passive, Anamod ATS-1, Eventide H3500, TC 2290, Yamaha D5000, PCM92, PCM70... Amps, Amps & More Amps. Last edited by Ghost In The Attic; 01-27-2018 at 12:37 PM. |
#149
Track presets are great. One use I’ve found is that, if you have a mix template.. with all your plugs, routing etc... you can select all of those tracks in your template and save it as a track preset. I put mine in a folder called “mix” and called the preset “Mix Template” now I can just create a new track and call up my mix template with one fell swoop. Saves doing the import session data thing. Love it.
#150
And all this because a lot of folks are superstitious...there could be a huge drop in sales because of the number 13! I think 2018 is a very elegant solution indeed. Big kudos to the Avid marketing team!
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins |
Pro Tools First 2018.1 Missing EQ Graph panel | Jakeman | Pro Tools | Intro Discussion | 5 | 02-06-2018 08:00 PM |
Welcome to the Pro Tools 2018 forum | DigiTechSupt | Pro Tools 2018 | 0 | 01-25-2018 11:35 AM |
Pro Tools v2018.1 Now Available | DigiTechSupt | Technical Alerts | 0 | 01-25-2018 11:06 AM |
Namm 2018 Pro Tools new hardware | zavid | General Discussion | 14 | 11-17-2017 11:20 AM |
