Old 07-01-2017, 03:42 AM
clausiii's Avatar
clausiii clausiii is offline
Default High Sierra TEST with APFS and PT 12.8
Hi!
I just want to inform you that i successfully TESTED Pro Tools 12.8 on the High Sierra public BETA on a TEST SYSTEM with the new APFS disk format!
Pro Tools, iLok, plugins, sessions, projects, Cloud Collaboration work as it should.
The OS is of course (its BETA!!!) buggy here and there, macOS needs significant less space than before.
So far so good. I'm confident that High Sierra and/or APFS will not break Pro Tools this fall.
Again, this is a TEST situation on a TEST system, don´t try it on a system with important data! And don't blame Avid when it doesn't work! ;-)
Even don´t blame Apple if your system breaks, use it on your own risk! And/or have fun beta testing!
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
Digidesign Command|8
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 09-12-2017, 08:30 AM
carboncitylights carboncitylights is offline
Default Re: High Sierra TEST with APFS and PT 12.8
I can confirm this as well! I have an iMac and a Macbook Pro. The iMac stays on stable releases while the macbook pro gets to have fun with Betas. I did notice that Ozone 5 is not launching on High Sierra though . Hope this gets patched soon!
Old 09-24-2017, 11:11 AM
crazy_jorgito crazy_jorgito is offline
Any more news on this?
High Sierra will be available in a couple of days and as I am running the last version of pro tools (12.8.1) im worried that it doesn't work.
Thanks!
- MackBook Pro Late 2016 (TouchBar):
Intel Core i7 @ 2,6 GHz (Turbo Boost @ 3,5 GHz)
16 GB RAM @ 2.133 MHz
Radeon Pro 460 with 4 GB of memory (graphics card)
SSD PCIe 512 GB
- Apollo Twin Duo MKII (2016) Thunderbolt
- Pro Tools 12.8.1
Old 09-24-2017, 11:29 AM
nedorama nedorama is offline
Thanks!
It's quite simple. If you're worried, then don't upgrade to High Sierra until Avid says Pro Tools is qualified on High Sierra with your Mac. You're not missing out on anything.
Unless you've imaged your hard drive, once you convert from HFS to APFS, there's no turning back, so this is not an update to be taken lightly.
Wait for the dust to settle, and let the rest of the early adopters on the DUC share their success or horror stories. I don't make money on Pro Tools, but any normal studio that depends on Pro Tools to pay the bills will be waiting for several weeks/months before updating.
Regards,
Ned
Monkey Boy Studios
2019 16" MBP, 32GB, 1TB SSD; OSX 10.15.7; 4TB USB-C G-Tech External
Summit Audio 2BA-221, TLA-50 -->Focusrite 18i20 3rd Gen, Eleven Rack, Pro Tools 2021.3
Plugins, Virtual Instruments, and real ones
Old 09-24-2017, 12:29 PM
Please upgrade as soon as possible and post any problems you have here. DUC is getting boring and what we need now is whole host of "I upgraded my Mac OS (for no reason) and now it does not work...." posts for our entertainment.
And thanks Clausiii for posting the (careful test) heads-up.
Old 09-25-2017, 02:25 PM
Hopefully someone can tell us soon if there are any problems.
SSD PCIe 512 GB
- Pro Tools 12.8.1
Old 09-25-2017, 10:51 PM
teedeecee teedeecee is offline
Received a new MacBook Pro today (refurbished MBP retina 15” mid 2014) and it had High Sierra installed. Thought it was worth a try to keep it at that OS as it’s primarily a Smaart/FuzzMeasure machine and they both seem fine on it.
Pro Tools HD Native 12.8.1 seems to be opening my current projects and running ok. Haven’t completed the install of all plugs as yet though.
So far, no issues, however I am certainly not going to upgrade my main studio PT systems until the dust has settled.
Old 09-27-2017, 08:32 AM
Voideco's Avatar
Voideco Voideco is offline
Originally Posted by clausiii View Post
Don´t try it on a system with important data!
Don´t try this at home lol.
Wondering if my PT 12.7.1 will work with this. Also, will my Metric Halo ULN8 + software plus other apps remain functioning on High Sierra? As far as I know, there is one user here with the ULN 8 interface so I will be eagerly lurking to see what hell this guy will go through (forgot his name, seen him only briefly).
Standby.
Mac Book Pro 2016 Retina, Quad core i7, 2,5 GHz, 16 Gb 1600 MHz RAM, 256 SSD drive, 500 Gb SSD USB3
OSX Sierra 10.12.5, PT 12.7.1, UVI Falcon 1.6
Metric Halo ULN8 3D Interface, NI Komplete Control S49 midikeyboard
Macbook Pro M1, 2.5 GHz 8 core CPU, 32 Gb RAM, 1Tb storage, Monterey 12.6.6. PT Ultimate 2023.6, UVI Falcon 3.0 + some soundbanks, Waves Platinum bundle, some free Melda plugz, Metric Halo/Make Believe plugz.
Old 09-27-2017, 09:01 AM
Gemylon's Avatar
Gemylon Gemylon is offline
I am using the ULN-8, and no, I'am not going to upgrade until PT clears ...
I'm fine over here atm
10.12.6 / PTHD 12.8.1
Cheers
Old 09-27-2017, 03:27 PM
As an update, my PT HD Native 12.8.1 install on a MBP retina 15” is running well, however I have found a few plugins that are rejected with PT popping up an error saying that they are not valid 64bits plugs. Some of the SlyFi and Massey plugs are being rejected sadly.
Overall though the system feels workable, and, maybe it’s confirmation bias, but actually more solid than my other machines. (Note I haven’t used this install for long though.)
[Update two days later, both the Massey and SyFi plugs are now ok - appeared to be a failed install process]
Sierra test drive dr_daw Pro Tools 12 8 10-24-2016 06:17 PM
Another PTLE Stress Test- "DaVerb Bounce Test" BioFeedback 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 02-11-2004 05:48 AM
digi 001 failed test 22 shared memory test the originalman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-14-2003 07:31 AM
Test 55 and test 123 in Digitest livearts Pro Tools TDM Systems (Mac) 1 10-11-2001 08:36 AM
Forum Broken test 1,2, test MacDaddy WGAR Pro Tools TDM Systems (Mac) 1 10-16-2000 06:56 PM
