Old 04-15-2019, 06:14 PM
tritonkorg tritonkorg is offline
Default Accidentally recorded over a midi track with Merge on
In brief:
Midi track 1 was recorded. Somehow I had record enabled the same track and recorded a piano performance...a long and pretty busy performance. Midi Merge was on, so now both performances are on the same midi track with notes all over the place. There's no way I can manually separate the two.
I desperately need to isolate/separate the 2nd (last) performance which is mixed and merged with the previous one. Is there any way to get these two separated besides having to go through the whole thing manually?
Old 04-15-2019, 06:33 PM
Sardi Sardi is online now
Default Re: Accidentally recorded over a midi track with Merge on
Does undo not work?
Old 04-15-2019, 06:58 PM
amagras amagras is offline
This ^ or see inside the session folder if there are any session backups
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 04-15-2019, 07:20 PM
Originally Posted by Sardi View Post
Does undo not work?
No it doesn't. This particular session was recorded 3 months ago. Besides how would 'undo' separate the piano from the previous track?
I don't care about track 1. I just want to isolate/rescue track 2 which is a really busy track. That was the last performance.
Old 04-15-2019, 07:23 PM
I have back ups, but how do you separate/extract the 2nd performance from the first? If I bring up a back up session, that'll show me the original performance. What about the 2nd performance?
Old 04-15-2019, 07:31 PM
I don't think that's possible, hopefully someone else has a better answer but I don't see any. Good news is this isn't going to happen to you anymore...probably
amagrasmusic.com
Old 04-15-2019, 07:38 PM
Sorry. I missed the part about you wanting to keep the merged performance. I thought you just wanted to remove it from the original part.
There’s no way to fix what you’ve done. Manually going through the MIDI clip and seperate get the notes is the only way. Depending on the performance, it may be fast or very tedious.
Best of luck!
Old 04-15-2019, 07:40 PM
I can't believe I did this! I just thought there might be a way to isolate a performance based on the date or something. Too bad!
Old 04-15-2019, 11:46 PM
moshuajusic moshuajusic is offline
Maybe import the original midi from a backup session as a new track, and then... something. At least you'll see right away which notes to delete from the "merged" performance. Maybe there's a way to overlay them? Might wanna try calling Avid, see if they have any ideas. If the original midi also included pedal work, this might be impossible.
Midi Notes already recorded drop when midi merge recording EdwardG Pro Tools 12 5 07-03-2019 12:44 AM
I Imported a Track Then Recorded Midi Track Now Changed My Tempo shamanrock Pro Tools 11 3 10-06-2015 10:56 PM
midi sustain on newly recorded track is effecting all other previous midi tracks awritersparadise Pro Tools 11 1 04-23-2015 11:02 PM
Accidentally recorded @ 48K within a 44K session! fingerz88d 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-08-2004 06:18 PM
Midi track is recorded. What's next? jk3horn MIDI 7 03-19-2003 11:18 AM
