Old 11-08-2013, 02:49 AM
tooold's Avatar
tooold tooold is offline
Default Plug-in link to Metric Halo console not working
I upgraded to PT11.0.2 a couple of days ago. Reinstalled 10.3.7 as well.
I use a Metric Halo ULN-8 for my interface, and the Metric Halo MIO Console for mixing; that's linked with Pro Tools with a plug-in called MIO Console Connect in an instrument channel. It allows saving of the setup in the MIO mixer with the PT session, and automatic recall. Once it's set up, it's pretty seamless, and sounds very good.
Out of the box, 10.3.7 worked as it had, although a lot of I/O setup had to be redone. I had problems with PT11 crashing when I inserted the Console Connect plug, which was the result of not updating everything from MH as I thought I had. So, now everything is updated, and no crashes in PT11.
However, I've lost the link between the Console Connect plug and the MIO mixer. Previously, I'd install the plug, and the mixer came up automatically. Now, nothing happens. I can run the Console as a standalone, and everything works fine, routing is correct, etc., but it's completely independent - everything has to be saved separately.
The worst part is that, before updating to fix the PT11 crashes, my old PT10 sessions worked as they should - the plug in linked with the MIO mixer no problem. Now, however, it behaves just as in PT11 - no link.
I've trashed PT prefs with no change.
I have a ticket open with MH support, but I'm in the UK and running five hours ahead of them. I though I'd check to see if anyone else using MH gear was having a similar problem. If someone else is working OK, then I obviously have a problem in my system, but it would at least narrow it down.
System 1: 2023 Mac Studio 64Gb RAM, OS 13.6, PT Native 2023.12, Metric Halo ULN-8, LIO
System 2: 2021 M1 Mini 16Gb, OS 13.6, Native 2023.9, MH ULN-8 4d
http://www.mylescochran.com
Old 11-08-2013, 06:51 AM
CME CME is offline
Default Re: Plug-in link to Metric Halo console not working
Just got this on the mailing list also. I'm just now updating to their newest versions and checking out the situation on my rig. I've got a 2882. I had tried out a beta version of CC and it was crashing PT10 so I just stayed put for an official release. I'll let you know what happens soon.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier.
Old 11-09-2013, 01:09 AM
tooold's Avatar
Problem solved. BJ Buchalter from MH came up with the solution (at 4 am US time) which was to send the MIO Console.app to the trash, then drag it back into the Applications folder. His suspicion is that Launch Services hadn't properly recognized the app, and re-dragging it to the Applications folder forced the OS to see it properly. I also re-ran the Console installer, but I had done that before with no luck, so I believe BJ's idea did it. Hallelujah!
Free AAX plug-in... Thump from Metric Halo Avid AAX Plug-ins 21 12-01-2012 05:06 PM
Get your free Metric Halo Thump plug-in txrx Windows 0 11-18-2012 10:00 PM
plug in opinions (mcdsp, metric halo and some pitch stuff) rfstudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 10-05-2007 07:35 AM
Metric Halo 'ChannelStrip Plug for OSX, PTs 6.1??? Adam Brown 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-01-2003 10:37 AM
Free Metric Halo Channel Strip SP Plug In For Mix 24 Mike Stosich Pro Tools TDM Systems (Win) 0 09-08-2002 06:06 PM
