Old 10-03-2012, 12:59 PM
eplust eplust is offline
Default Targeted tempo automation?
Hello,
New to the forums, I apologize if a similar thread has been posted.
I've recently made the switch to PT from DP; as clunky and confusing as DP may have been, one strong advantage was its MIDI capabilities, specifically its tempo automation. In DP, you can highlight a selection and have DP calculate a desired tempo map (be it accelerando, decelerando[for which you'd have to pick a start tempo], or constant tempo) to have the end of the selection (targeted beat) fall on a tick or frame of your choice. I was wondering if PT had anything comparable; I poked around a bit and couldn't find anything. In previous versions of PT I just had to draw tempo curves and futz around until the beat I wanted hit the frame I wanted. The reason for frame specificity is synchronization; frame specific tempo automations are immensely useful in film scoring.
Thanks in advance for all your help! :)
Old 10-15-2012, 10:35 AM
Default Re: Targeted tempo automation?
sorry for the bump; anyone have a solution to this?
Old 10-15-2012, 11:33 AM
jasonthurley's Avatar
jasonthurley jasonthurley is offline
This is mostly done in Beat Detective although I don't mess with it much... You can probably find some tutorials online.
Gradual automation of tempo is never exact. phillyt2k Pro Tools 10 7 04-18-2013 10:38 AM
Tap to tempo automation and Echoboy Jakob Clemen ICON & C|24 1 12-30-2012 03:33 PM
Automation, Plugin, write-to-all-enabled, but only for the currently targeted Plugin joachim Pro Tools 10 3 07-11-2012 10:48 AM
Automation follows Tempo or Time Compression? J.D. Andrew Pro Tools TDM Systems (Mac) 1 01-03-2007 07:17 AM
Tempo Automation on Delay Plug-in doug_hti Pro Tools TDM Systems (Mac) 8 10-30-2002 07:40 PM
