Old 11-05-2013, 11:33 PM
ThunderKyss ThunderKyss is offline
Default M-Audio Oxygen??
I've got an old M-Audio Oxygen 49 midi controller.
I just happened on a youtube video & saw a guy, with a newer "blue" Oxygen 49, using the buttons & faders to control protools channel strips, the faders, the mute, solo, & record enable buttons.
According to what little bit of googling I've done, it appears there's a special program built into the blue controllers that work with the directlink drivers built into pro tools that allow this to work automatically.
Is there a way I can program these buttons on my controller to do the same thing? I'm not so much worried about the faders as I am the mute, solo, record enable, toggle metronome, toggle loop playback & toggle loop record.
I'd really like that functionality & if I can't program my controller to do it, what are my options? I've seen the MC Transport ( I like it, but don't know if it's any different than grabbing a mouse), I've seen the Axiom Pro Keyboards, I know I could just buy a "blue" Oxygen... do you know of other alternatives?
MacMini OS x 10.14.6
Core i5 2.5 GHz 16GB
Eleven Rack
Old 11-11-2013, 07:51 PM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
Default Re: M-Audio Oxygen??
You'd need to program it to emulate a supported controller. There used to be more choices, back in the day when the Jlcooper CS10 was still supported I programmed quite a few controllers to emulate the cs10. I think all you have now is the hui protocol, not sure which CCs it uses, you'd have to do some research.
P.s. A relatively easy thing to start with is the transport controls. Enable MMC in pro tools, and program the transport buttons to use MMC protocol. Look in the axiom manual for the specs.
- John
If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound?
Old 12-05-2013, 10:49 PM
Seafoam_Green's Avatar
Seafoam_Green Seafoam_Green is offline
M-Audio call their technology that controls functions in protools - "hypercontrol"
I have your same issue with my axiom 2nd generation controller keyboard .
Ive emailed M-Audio about it not working in later versions of protools 10 , let alone version 11 , and they replied that they will be updating the drivers soon to add hypecontrol to these protools versions ??????
By the end of the year they hoped but wouldnt commit to any actual dates ...., ...., they better hurry up the years almost out
Old 12-06-2013, 10:52 AM
Just to clear up any confusion, the OP's pictured keyboard is an older "Oxygen" model and does not support the newer hypercontrol protcol. The only way to control pro tools with an older oxygen keyboard is to program it to output the same MIDI CC's as a supported controller like a Mackie HUI uses. If you are using an older version of pro tools, there are other controllers like a CS-10 that it can be programmed to emulate. (See the old digidesign MIDI controllers guide for a complete list of CC's that the CS-10 used).
It's also noteworthy that there are 2 recent M-audio protocols for controlling pro tools: Hypercontrol and Directlink. iirc, Directlink is what the Gen1 Axiom (Black) keyboards used, and Hypercontrol is what the gen2 Axiom Pro (Silver) Keyboards use.
- John
M-Audio Oxygen 25 Councillor Getting Started 11 11-05-2013 11:13 AM
M audio oxygen 3rd gen RettRobinson MIDI 0 01-25-2010 03:32 PM
just got the M-Audio oxygen 49 v2 jonslaten MIDI 6 12-28-2009 04:08 PM
M audio Oxygen 8 rabs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-12-2006 03:41 AM
Oxygen 8 M-Audio Edson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 12-30-2004 12:07 PM
