#31
Re: Urgent: Serious issue with clip effects
Thank you so much, Farhoof. My monitor's gray scale must be set so low and the colon so small that it looks like 1.01 instead of 1.0:1! I'll recheck.
Ironically, I changed it in order to test and of course if I change the makeup gain or the ratio then it applies gain or starts compressing so I assumed that the compressor was engaged with a 1.01:1 ratio.... Same with the Gate. Case closed, for now. Though I would prefer for peace of mind to see all those elements bypassed, with the Engage buttons for the comp and Exp disengaged till the user wants them. This thread has run its course, thanks very much to Farhoof. Bob Quote:
Clip effects and dock | Moviesound | Avid S1, S3, Dock and Control App | 5 | 08-11-2017 11:47 PM |
Clip Effects | SBP | Pro Tools 12 | 1 | 06-12-2017 04:19 PM |
Disable Clip Effects | markuse_23 | Pro Tools 12 | 0 | 01-31-2017 03:06 AM |
Clip Effects Freezing | Carl Lie | Pro Tools 12 | 3 | 10-05-2016 04:24 AM |
Issue dropping more than one clip into the Edit Window with Clip Transparency ON | arb232 | Pro Tools 12 | 0 | 02-10-2016 06:01 PM |
