Re: Cannot Edit Clip Effects in PT 12.6 HD
Having similar issues - intermittently cannot use certain parameters of the clip effects. If I copy the clip and paste it somewhere else on my timeline, I somehow gain the ability to edit all parameters again. Not clip specific or project specific, seems to be pretty random.
Example (not my video but illustrates problem): http://youtu.be/nThgRt9NLPc
http://mackcut.com |
I'd like to hear from anyone who is actually using clip effects on a pre 12.6 session. Not someone who tested it on a clip or two and called it a day. C
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc. |
You'd be surprised.......
Merely seeking to add detail to a thread that is about an issue that seems to be intermittent. I recently mixed a documentary and used Clip FX extensively and didn't experience this once for example. Now.... Fixable bugs need reproducible steps. Can anyone here make this happen with a brand new session following specific steps? That would be super helpful. |
Deleted.
Glad to know it actually works for you though in real life. You never know when people say something works if their really using it. C
#16
For what it's worth, this happens to me in a brand new project; however, I did import my audio from an Avid Media Composer AAF.
Chris |
#17
Has anyone already listed this bug at Ideascale?
It's such a showstopper what i encounter every day, since Clip Effects have really speeded up my worlflow in Post sessions. Haven't figured out how to reproduce this bug, but here at Duc, Goombot suggests: "After further use it seems to only happen when you keep the clip effects window open" |
#18
Chris |
#19
And yes, this would be wonderful for Post, as it allows me to make tiny tweaks to dialog clip to clip, without having to mess with automating parameters, etc. Very keen on getting this bug squashed.
Chris |
#20
Just started playing with Clip FX and am seeing this as well. Just done a restart, and will see how it lasts.
Session came from AAF, but audio I'm tweaking is from my SFX library... |
Clip Effects Freezing | Carl Lie | Pro Tools 12 | 3 | 10-05-2016 04:24 AM |
Clip Effects - Compression Metering?? | off the wall | Pro Tools 12 | 8 | 09-30-2016 09:59 AM |
Clip Effects Enabled by default | cshaw | Pro Tools 12 | 0 | 09-30-2016 08:52 AM |
Clip effects not working [SOLVED] | cshaw | Pro Tools 12 | 5 | 09-30-2016 05:22 AM |
Issue dropping more than one clip into the Edit Window with Clip Transparency ON | arb232 | Pro Tools 12 | 0 | 02-10-2016 06:01 PM |
