Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 05-18-2009, 03:20 AM
slimpunk slimpunk is offline
Default PT 7.4 M-Powered Not Compatible w/ Avid MC?
Hey everyone,
I just discovered that it's apparently impossible to run PT and Avid MC 3.0 off of the same hard drive. This would explain why neither program is able to start up for me now (having just installed MC on top of PT).
So the way around this is to install one of them on a separate start-up disk? Or does anybody know another way?
I would upgrade and buy PT 8, but apparently the M-Powered version doesn't support Digidelivery, so that's completely useless to me.
Thanks in advance!
Old 05-18-2009, 05:22 PM
DigiTechSupt's Avatar
Default Re: PT 7.4 M-Powered Not Compatible w/ Avid MC?
The only way, if you want to do so in your current situation, is to install them on different drives (typically clones of the same OS install).
I'm a little unclear about this - M-Powered may not support it directly from within Pro Tools, but you can still easily send sessions via Digidelivery by dragging and dropping the session folder to the Digidelivery window.
Avid Audio Tech Support
Support FAQ
Old 06-05-2009, 03:39 PM
OK, thanks very much for the info!
Is PT9 compatible with M-Powered interfaces? Hercules Pro Tools 9 1 11-04-2010 07:24 PM
Dear Avid, will the Complete Production Toolkit ever be compatible with M-Powered? TheDigitalBlack Pro Tools M-Powered (Mac) 3 10-11-2010 09:19 PM
Any Drum Modules Win 7 64 bit compatible w/PT M-powered? OneZoso Virtual Instruments 7 09-01-2010 10:34 PM
Is Pro Tools m-powered 6.8 compatible with Mac os x 10.3.9? szodiac1086 Pro Tools M-Powered (Mac) 2 08-21-2007 05:36 PM
compatible with pro tools M-Powered? remie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-13-2006 11:54 AM
