MIDI loses sound on instrument tracks
When I create an instrument track and add MIDI performance instructions I then select an instrument (sounds) for the instructions to play This is usually done in the same step by the virtual instrument. Everything works fine initially. After I close the Pro Tools session and reopen it at a later date the MIDI instructions are still there but the instrument assignments are missing. I used to be able to drag the Plug In for the virtual instrument to another slot on the same track and magically the assigned instrument would activate again. Consequently the MIDI notes clips changes from see through to colored when the instrument is reassigned.
Right now I am working with Addictive Drums 2 as the virtual instrument Plug In but I have also experienced this with Xpand!2. It has also happened on Pro Tools 11 and now 12. Any ideas?? |
Re: MIDI loses sound on instrument tracks
Which version of Pro Tools 12?
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 16GB RAM ProTools 2020.11 Avid S1 Avid Dock Avid Control Digidesign Command|8 macOS Catalina MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise |
First of all, be sure you have the instrument block visible in the mixer. View / Mix Window Views / Instruments. Then from the dropdown menu (second from the top) choose the instrument you wish that track to play. Now it should work.
You sir are a GENIUS!!
Gracias |
MIDI tracks are recording an unwanted instrument sound | Jen H | MIDI | 1 | 10-05-2012 06:39 PM |
2 instrument tracks each controlled by different MIDI input/instrument | Midimax | Pro Tools M-Powered (Win) | 0 | 03-20-2012 03:10 PM |
Instrument tracks won't sound! | [email protected] | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-22-2009 09:56 PM |
MIDI Tracks Versus Instrument Tracks. VERY Confused. | Rick540 | MIDI | 8 | 12-04-2008 11:04 AM |
No sound from "Aux Input" and "Instrument" tracks | slowdude | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-25-2005 03:46 AM |
