Old 12-17-2016, 03:44 PM
asm's Avatar
asm asm is offline
Default D-Command Record + Play button issues
Hello,
Recently (maybe since 12.6) if I hit the record button to put the transport into "record ready" mode and then hit play it will not enter record mode but instead playback mode. Once transport is in play then hitting the record button again will record on all armed tracks.
"Command-Spacebar" works as intended, just cannot enter record from the D-Command.
Anyone else notice this?
Thanks
Andrew Mittelman
www.soundgeneration.net
Old 12-18-2016, 12:26 AM
Watagushu2013 Watagushu2013 is offline
Default Re: D-Command Record + Play button issues
It's not a protools version problem. I had it and I think id due to some configuration on the transport maybe. Let me think what I had done to solve it.........
Old 12-20-2016, 07:24 PM
asm's Avatar
asm asm is offline
I checked every preference I could find but still cannot restore the functionality.
Anyone else having this issue, or had it before?
Thanks
Andrew Mittelman
Old 12-21-2016, 12:47 AM
Stig Eliassen's Avatar
I believe I experienced this once, and the cure was to delete PT prefs.
Old 12-22-2016, 03:17 PM
Also yo can check if at the top and right of the d command are some buttons that link the timeline to the transport. Try fuzzing around with them to find the correct behavior you are looking for. I think are colored blue.
Old 12-23-2016, 12:11 PM
asm's Avatar
asm asm is offline
I think trash preferences did it, but I also updated to 12.7 so not sure
Either way it is working again.
Thanks all
Andrew Mittelman
Old 12-23-2016, 02:09 PM
jacko's Avatar
jacko jacko is offline
Recently I lost mark in/out buttons while in playback. Trashing preferences did the trick too.
UAD Apollo x16,
UAD Apollo Twin Duo,
UAD Octo Thunderbolt,
Mac Mini i7 2018,
Reaper DAW,
Presonus Faderport,
Arturia Beastep for DAW control,
Former Pro Tools HD user (from V7 until V12.6).
Old 02-22-2017, 08:38 AM
dellel dellel is offline
Watagushu's suggestion fixed it for me.
Old 02-22-2017, 08:41 AM
Barry Johns Barry Johns is offline
I've been having the same issue, and its driving me nuts! Its not PT12 specific, as its happening to me in PTHD11.
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors.
MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp
Old 02-17-2018, 11:34 PM
Jeezer Jeezer is offline
For anyone else looking, the button on the D-Command's monitor section top right in the 'timeline'box (where you change what the counter shows), press the 'edit/t-line' button so the light is on the right (t-line).
This cured this issue for me. No prefs trashing needed!
can't play or record, stop button lights up robotboy Pro Tools 10 4 08-04-2014 08:34 PM
D-Command's Play button and Edit Menu problem diegogat ICON & C|24 2 10-02-2012 12:49 PM
Play and record button/bar is not visible Nomerone Pro Tools SE and Essential (Win) 0 01-16-2012 09:44 AM
Delay When Record/Play Button Pressed kaoticjackal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 06-25-2009 01:42 PM
key command for Record ready button? Fritz Pro Tools TDM Systems (Mac) 7 07-06-2006 09:43 PM
