Old 11-07-2014, 04:33 PM
ha2dorff ha2dorff is offline
Default Mark in - mark out, select area
For hours each day I need to select an area of an audio clip (and do further work that is too much to describe here).
The way I do that:
I listen to the audio and press arrow down at the start point, and arrow up at the end point. Or select the area with the mouse.
If I for some reason miss the out point, I have to find exactly where I want to end my selection.
But then I have lost my in point...
Is there a way to set "permanent" in- and out points, and then make selection between them?
A way could be to use two permanent markers for in and out, and drag the markers with me through the project.
But is there a function for this?
Old 11-08-2014, 08:29 AM
RyanC RyanC is offline
Default Re: Mark in - mark out, select area
You can separate timeline and edit selection and use the key commands O and 0 (cmd focus mode) to copy from one to the other. Then use arrows to select edit region and copy up to timeline, once you find the appropriate ending point copy it back down from the timeline and hold shift before clicking the right edge of the selected edit selection (inside the grey).
Tab to transient may also be handy with the shift key (select up to next transient). Also you can adjust edit selection end by nudge value with shft cmd num pad +/- (start is sft opt nm pad +/- ). You can increase or decrease nudge value with opt+cmd +/-.
Or if you select the scrubber tool after making the selection and hold shift and click inside the grey to edit the endpoint while scrubbing.
Old 11-08-2014, 09:55 AM
Thanks, RyanC. I'll try that tomorrow
Old 11-08-2014, 12:40 PM
joachim's Avatar
joachim joachim is offline
Permanent markers, I do not know ... but maybe new ones :
playback, hear in-point : quickly enter enter (numeric keypad) to create a memory location #1
hear the out-point : quickly enter enter , memory location #2
stop playback
memory locations window : select #1 , shift-select #2 , makes a selection
possibly : alt - , to correct the start point at little bit earlier , ctrl - , to correct the out-point a little bit earlier (due to human reaction time for listening/realizing/hitting enter enter)
when done : alt-click mem loc #1 and #2 for clean-up
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 11-08-2014, 01:24 PM
Thanks, Joachim. I think I do it that way and let Slate Batch Commander do the job :)
Old 11-09-2014, 10:38 AM
The Weed's Avatar
The Weed The Weed is offline
There is a setting in Preferences to allow one "Enter" to drop in a Marker when Playing or Recording.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 11-09-2014, 10:54 AM
joachim's Avatar
Good point ! (The Auto-Naming)
Old 02-09-2018, 09:37 AM
midnightsun midnightsun is offline
Very useful thread.
Old 02-10-2018, 09:01 AM
Don't forget that there are one-key shortcuts for "Play Up To In Point", "Play from In Point", "Play Up To Out Point", and "Play From Out Point" - these can be very handy for refining your start and end times.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 02-10-2018, 04:02 PM
Another option; drop a marker at the front and another at the end. Select the front marker, hold SHIFT and select the end marker. To make that a "permanent" selection(while its highlighted), hit Enter as if you were going to drop a marker, but go on the Marker Properties box, uncheck Marker and check Selection and hit Okay. Now when you select that marker from the list, it will select that same portion of the timeline and audio
Mark out druth77 ICON & C|24 6 04-03-2011 06:21 PM
Mark Lalaman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 04-16-2002 07:33 AM
Mark Of The Unicorn JoshyBlue 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 03-26-2002 12:16 AM
Mark's last name sessiondude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 03-14-2002 05:28 AM
how to use mark edit start mark edit end keys c-post Tips & Tricks 1 02-07-2002 09:35 PM
