Pro Tools Relaunches after Closing
Hi all,
I am currently running version 2021.6.0 PT on windows 10. The build has been stable for the last 10 months or so with zero issues. Yesterday, using BlueCatPatchwork, I opened an old vst3 into a couple PT sessions (legacy version of Slate Virtual Tape). Now, upon closing pro tools post-save, it immediately relaunches. I have to go into task manager to abort and stop the cycle. I have since deleted what I thought was the problematic VST, and the problem persists. I have cleared my preferences and roaming folder, the problem persists. I removed every plugin from my plugins folder, re-added them back systematically to try and identify if any specific plug-in was problematic (I have around 500). This resolved the issue temporarily, and I was able to create new sessions and close them. Pro tools stayed close. Going back into the problematic sessions initializes the boot loop. The boot-loop itself is merely an inconvenienced, more so I fear the quitting process for the application is being interfered with and I am afraid of losing session data. There is no warning or splash screen upon the relaunch. Sorry for the long post, any advice helps. Cheers |
Re: Pro Tools Relaunches after Closing
Ok. I believe i've found the solution if anyone is interested. Upon removing Nomad Factory (consisting of AMT Amp Leveling, AMT Max Warm, AMT Multi-Max), I've solved the crash loop.
I'm guessing it had nothing to do with bluecat's wrapper. Max Warm is on every one of my Mix Bus's so it'll be a pain to find a good replacement, but those plugins are not cooperating well with pro tools at the moment. |
Glad you resolved it. Thank you for sharing the solution. It might help others with a similar issue.
Protools relaunches after shutdown | wornthin | Pro Tools 2019 | 5 | 11-14-2019 07:48 PM |
error by closing pro tools 9 | harryheylen | Windows | 5 | 02-09-2012 12:37 PM |
pro-tools 8 keeps closing please help | zionsnoiz | Pro Tools M-Powered (Mac) | 2 | 03-08-2011 04:41 AM |
Pro Tools Closing | RobtheRipper | Pro Tools TDM Systems (Mac) | 4 | 09-03-2008 08:29 PM |
Pro Tools closing on me! | manicdown | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-17-2007 11:40 PM |
