Old 11-09-2018, 11:39 PM
mgoorevich's Avatar
mgoorevich mgoorevich is offline
Default Re: D-Verb warble
Originally Posted by LSD-Studio View Post
Well, “better” is not an objective term.
I’ve got revived an relab480 any many more fantastic reverbs that I live and that sound “better”.
But this almost cheap sounding graininess of d-verb is perfect for metal snare drums, I have not found a single one that does the same thing for me, it’s become a massive part of my “signature” drum sound.
I would never use it for anything else since I got “better” sounding reverbs, but this one thing it does on snares is something that no other reverb can do for me. With today’s processing power it really shouldn’t be a problem for avid to fix this, a lot of people are still using d-verb (in fact many of my colleagues are using it for that very same reason$.
Avid will not fix it, don't hope for it...
While I completely understand your nostalgia for d-verb, at the end its just the matter of "home work". You will find a modern replacement of d-verb if you simply open yourself to trying all these new plugins...
Try Exponential Audio, some of their plugins have built in EQ, Distortion and Dynamics algorithms to make it sound right.
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3
MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM
MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24
Old 11-10-2018, 12:16 AM
Sardi Sardi is offline
It has nothing to do with processing power. The modulation was added in later versions. If anything, the additional modulation would require more CPU power.
If you really can’t do away wth that grainy sound, here’s a suggestion. Go back to the old version if you can and create an IR of that setting that you like and load it up in any convolution plugin. Done!
If you can’t load the old version that doesn’t have the modulation which, from memory, was the RTAS version, then I’m sure you can ask one of your colleagues to do it for you.
Old 11-10-2018, 12:31 AM
LSD-Studio LSD-Studio is offline
That’s a great idea actually, thanks!
Old 11-10-2018, 01:32 AM
Indeed it is.
Done it for myself and others numerous times.
Old 11-10-2018, 02:47 AM
Damn, used the sweep Waves supplied and created an IR for IR-1 according to their guide.
still doesn't sound the same (initial attack, high end and stereo spread seems off)....
well, guess I'll just have to say good bye to dVerb then.
thanks anyway!
Old 11-10-2018, 05:37 AM
thanks anyway!
Well I just tried it using the Plate setting as that doesn’t have any modulation. Sounds pretty damn close to the D-Verb version to me.
I use Voxengo’s deconvolution plugin with a 6 second sine sweep. The IR reverb needs to be increased by a couple of dB, but that’s to be expected. Aside from that, I think it’s pretty much the same and in the context of a mix, I’d say virtually indistinguishable.
Is this the first time you’ve created an IR? Perhaps you’ve done something wrong along the way?
Old 11-10-2018, 06:03 AM
Nah, have done it a couple of times.
But this one was particularly easy since I literally just used the sweep that waves supplied specifically for this purpose.
Run it through the reverb and print the wav.
Then literally just import wav into IR-1, that’s it, IR-1 is doing the deconvolution process etc for you.
Literally fool proof, zero chance to fck something up.
Old 11-10-2018, 03:18 PM
Well something is up, as the process works fine for me.
If that D-Verb setting means that much to you, I’d investigate further and perhaps try a different piece of sw for the deconvolution process.
Old 09-09-2019, 08:46 AM
Just found this thread and wanted to add my 2p.
I've hated the modulation in D-Verb since I switched over to HD Native from TDM. I've just tried convoluting using the IR1 and I think I've got it to sound pretty damn close - at least, for my needs. The overall output level is a bit out compared to the D-Verb so that needs adjusting manually, but otherwise pretty happy.
NB No point people putting "just use another reverb". I have a bazillion fancy reverbs, most of which I've found to be completely useless in the context of a mix. The D-Verb does its own thing and - depending on context, of course - what it does works pretty well.
HTML code is On
is there a way to get rid of elastic audio warble sound. evilstudios Pro Tools 11 10 12-23-2013 10:28 AM
Pro Tools 10.1.2 Elastic Audio Warble rogercollege Pro Tools 10 8 12-02-2012 05:41 PM
Dolby Warble tone?? Anyone? Boom Chic Post - Surround - Video 4 03-24-2002 11:35 PM
MP3s WARBLE after Import into PTools....What Gives? tomhartman Pro Tools TDM Systems (Mac) 0 07-18-2001 01:15 PM
High Frequeccy Warble Sound? lamp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-03-2001 08:03 PM
