Trashing DAE Preferences - Export Automation
I've had some trouble with apparently corrupted
files, apparently in conjunction with a plug-in. When I close the session it gives me a kernel32 error, swap file probelm and then I have to reboot to run PTLE again. What do you lose when you delete the files in DAE Preferences? Is there a way to import/export the automation information from a 'corrupted' session in the same way you can import audio? Thanks. |
Re: Trashing DAE Preferences - Export Automation
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>What do you lose when you delete the files in DAE Preferences?<HR></BLOCKQUOTE>
-Whenever you trash the DAE preferences, remove the entire folder (it will be created again when you relaunch PT LE). The DAE preferences contain information about what plug-ins are currently installed in the system as well as the DAE Playback Buffer size. <BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Is there a way to import/export the automation information from a 'corrupted' session in the same way you can import audio?<HR></BLOCKQUOTE> -Not really. The only way to import automation is by importing the entire track (File>Import Tracks) into the session. Brent |
Trashing Preferences | jryser | macOS | 0 | 12-17-2011 12:56 PM |
What if when you were trashing preferences... | Wheeltard | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 12-28-2010 12:28 PM |
Trashing Preferences | paul_g | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-23-2009 06:56 PM |
trashing preferences | temb0 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-25-2009 04:27 PM |
trashing preferences | Cmill | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-13-2007 05:05 PM |
