Avid Scorch
Avid Scorch (iOS) Forum
Scorch Forum Home Page
Forum Terms of Use
Scorch for iPad Support FAQ
Avid Scorch
Go Back   Avid Pro Audio Community > Other Products > Avid Scorch (iOS) Forum
Old 09-03-2015, 05:32 AM
Lisa Aberdeen Lisa Aberdeen is offline
Default Still problems with slowing down tempo to practice
I can see that has been causing a problem for some time . Having taken a look at the forum the suggestion to still use the slider without anything being visible does not work for me. Everything is still playing back at 100% speed which is useless for practicing. I have had this problem for over three months now and uninstalled and reinstalled a number of times. Please can someone advise when this will be getting fixed. The app I had found had been really useful as a practice tool but this is rubbish if I can't slow pieces down and I refuse to purchase any more sheet music to work with the programme until it's fixed.
Old 09-20-2015, 04:08 AM
Neffer Neffer is offline
Default Re: Still problems with slowing down tempo to practice
I have the same problem. Help! Any ideas?
Old 09-20-2015, 04:49 AM
My son just discovered a fix. The slider bar is just hidden. If you centre it (double click in it to 100%) then the slider position will be in the middle (even though you can't see it) Place your finger in the middle as if it were really there, and use it as you would normally. As long as your finger is over the invisible slider it will work! (Pretty stupid fix really - Avid should fix it properly) 😊
Slowing down tempo walt68 Pro Tools 10 2 04-15-2014 04:18 PM
Best method for slowing down tempo? kirkbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-17-2009 08:39 PM
slowing tempo jetidd Tips & Tricks 0 07-18-2006 05:09 PM
slowing down tempo thesego211 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-04-2005 12:07 PM
Slowing down the tempo MV Tips & Tricks 6 11-29-2002 01:19 PM
