Old 06-09-2008, 12:33 PM
seolwoo seolwoo is offline
Default Automation problem
I have a weird problem.
I set volume automation, but it is not changed at all.
I mean, for example, I set +12dB at the specific spot on the track, but the sound doesn't come out that much louder from my speakers.
I can see the automation works in PT, but I cannot hear any difference of volume.
Of course, I checked my speakers and reset, but it didn't solve the problem.
What should I do?
It's my first time to have this kind of problem.
I heard that it can be solved by removing a file at preference, but I don't know what file it is.
Anyway, help me guys!
Thanks!
Old 06-09-2008, 01:33 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Automation problem
Under the window menu you will see the automation window. (also pressing apple+4 will bring it up) do you have volume hi-lighted? it should be a white background with volume written in red. (If its grey, then its turned off)
Chris
Producer, Engineer,
www.ukmastering.com
Old 06-09-2008, 02:46 PM
elicious elicious is offline
you can see you're fader jump or you just see the auto line in your edit Screen?
you might have your auto suspended.
e
ihatetyping
Old 06-10-2008, 08:18 PM
I can see the faders are moving, but sounds are just the same. (no differences)
Thanks,
SW
Old 06-10-2008, 08:20 PM
Now, I'm not in my office, so I'll try that later.
Thank you so much, Chris!
Old 06-10-2008, 09:09 PM
Shawn Simpson Shawn Simpson is offline
Chris
This will only effect the system's ability to write automation in realtime. It will not effect whether automation can be created graphically or whether it will playback regardless of how it was created.
If the fader is moving and there is no change in the output volume, you are either listening to something other than the track you're automating or the track is hitting some sort of brickwall limiter. Is this happening on all of the tracks in your session or is it only a specific track?
Anyone Had This Automation Problem? tomhartman Pro Tools TDM Systems (Mac) 1 04-06-2007 07:54 AM
Automation Problem rastro2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-24-2007 09:55 PM
Automation problem jaketanner 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-19-2006 06:10 PM
Automation Problem March314 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-10-2005 10:55 AM
Automation problem Jeff Zubeck Pro Tools TDM Systems (Mac) 2 01-02-2002 04:43 PM
