Pre Amps
I have a 001 but want more XLR inputs so i am able to record drums, but was wondering what to go for in terms of Pre amps. I was in two minds of whether to get a Presonas Digimax, Mackie Onyx 800R, or a Mackie Onyx 1620 desk and jun the line outs to the line ins on the 001.
Any Suggestions. Cheers Harrison |
Re: Pre Amps
Welcome to the boards! With an 001, you can max it out up to 16 tracks all together. With pre's, you really want to let your ears give them a listen before purchasing with your fav. microphones. A lot of the lower end pre's will not be worth the time and $$ spent if you are looking for quality audio to be honest with you. Best deal is to go to your local audio shop and give them a listen. goodluck
Re: Pre Amps
I LOVE my DigiMax LT!
5198 Studios |
Re: Pre Amps
I could be mistaken about the 001 but I am almost posative that the 001 is capable of 18 just like the 002. It requires both adat and spdif though.
In laymen terms. 2 pres and 8 converters come standard on the 001. You can add 8 more inputs of digital input via adat, and 2 more inputs of digital input via spdif (or you can use the light pipe for an optical spdif but most folks prefer the extra inputs). So to add 8 more via the lightpipe adat you need to purchase something that has 8 converters that outputs to adat. The two most commonly found and most highly recommended gear that folks purchase are the octopre with the added adat interface (i have one) and the digimax and digimaxlt. These interfaces all feature high quality mic preamps and converters and the octopre and digimax both feature compressors and limiters (i think the digi max does anyway). These run about 800 for the lt to 1200 new for the octopre and digimax (at least when i bought mine a couple of years ago) and should do fine unless you are looking for the specific sounds of really expensive pre's like neve's (or clone), avalons, etc. Thing is if you decide to purchase the more expensive pre's you will only get 1 or 2 channels and miss out on the converters and still probably spend more money. Most folks here purchase one of those units for adat and then when they have enough money purchase a really high quality 2 channel pre (like the ones mentioned above) and purchase a high quality rca spdif converter for solo instruments (vox, and acoustic instruments). By the way the octopre, and digimax units all provide a major upgrade in sound quality over the 001 stock inputs. Good luck. Christian |
Re: Pre Amps
Use your ears. I like Amek. Usually use that on all vocals for my pre. I also have 2 Hardy M-1's that are great, very smooth and rich. If you are on a lower budget, the hardys aren't THAT expensive. For Drums, API makes a 4 pre unit called the lunchbox. They are pretty clean pre's and not very expensive. That doesn't cover your input situation though, they are XLR output.
------>MY OPINION<----- No matter what, never use the control 24's pres. They are just dull and have no presence. I'll only use them for talkback and listenback mics.
Mac Pro 3.7 Quad Core Intel Mac OS X 10.13.2 PT Ultimate HDX 2019.10 64GB RAM HDX I/O 16x16 Analog HDX I/O 8x8x8 |
Re: Pre Amps
I'm using the ADAT connection and a focusrite Octopre LE (for drums). It's worlds better than the Behringer ADA8000 I had (more $$ though too). then I have another pre connected via S/PDif for a total of 18.
Pro Tools 2022.9 UAD Apollo 16 (v10.1) Dell XPS 8940 (i5-11400) Win10 www.studiodrumtracks.com www.doubledogrecording.com |
Re: Pre Amps
I just ordered the mackie 800R. Its for drum tracks with my 002R. I have been reading about the preamps you mentioned. The octopre looks good as well but you have to buy the extra card for light pipe. The mackies onyx preamps are supposed to be the bomb. And its going to replace my mackie 1604vlz pro which has been a excellent peice of gear. And it comes with the optical connects already. My 2cents
Re: Pre Amps
what about the rosetta 800? or is that converters only?
"I never hit a women with her clothes on!" |
Re: Pre Amps
Re: Pre Amps
PT Ultimate 2020.3.0 1 HDX Card Lynx Aurora 16 (2) Windows 10 Pro 1909 ASUS X-99 II Intel i7 32GB RAM Gigabyte GeForce GTX 1050 Ti 4GB www.doylemusic.com |
Mbox 3 Pre amps vs. External Pre amps? | evanbgrove | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-10-2011 05:21 AM |
Mbox 2 pro... Pre Amps (vs) 003 Pre... Amps | Norm Mix | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-24-2009 02:37 AM |
mic pre amps | LadyElectrikStudios | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-12-2002 02:20 PM |
Top Hat Amps | EjA | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-31-2002 09:12 PM |
pre amps ? help me!!!!!!!!! | ariel keshet | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-17-2002 08:52 AM |
