Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
Old 03-19-2017, 01:59 PM
Leadplayerchris Leadplayerchris is offline
Default Fast Track C600 Stretched Audio
Good day,
I've got a bit of a problem, My Fast Track C600 recently started playing all audio stretched like an old tape. What I've tried so far is..
1. Uninstall and reinstall the latest drivers.
2. Uninstall and install previous driver.
3. Unplugged everything including PC.
4. Try a different USB cable.
5. Try a different USB port
6. Try the interface on a different computer.
All attempts have been futile...
Please HELP!!! this is urgent
Old 03-20-2017, 04:47 AM
JoelG's Avatar
JoelG JoelG is offline
Default Re: Fast Track C600 Stretched Audio
Do you have your sample rate set properly? Are you using this for your Windows sounds as well (YouTube, Media Player etc.), or exclusively for your DAW?
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 03-20-2017, 06:04 AM
Hi, yeah I've got everything on default settings, even set the sample rate to 44.100/16bit and the same thing, what I notice is that if I plug the unit in only using the usb, it works for a while then starts to do the same, as soon as I plug in the power chord all the lights dim down a bit and the blue power led goes off, pc gives a message then saying usb device not recognised.
Old 03-21-2017, 06:43 AM
JoelG's Avatar
That sounds like a physical problem with the C600. Can you try it on another computer?
Joel
Jam Space:
Home:
Rig:
Old 03-21-2017, 07:17 AM
Yeah I tried it and did the same thing on there. Think I'll have to replace it...
M-Audio Fast track C600 - Spdif not working? moonwalker2 FireWire & USB Audio Interfaces (Win) 2 05-26-2016 03:18 PM
Fast Track C600 Record Audio From Ableton seanconor FireWire & USB Audio Interfaces (Win) 1 05-08-2015 08:25 AM
M-Audio Fast Track C600 problem installation fairforce Le Forum en Français 2 03-20-2015 08:16 PM
M-Audio Fast Track C600 gain? Dingzie FireWire & USB Audio Interfaces (Mac) 7 11-10-2014 03:17 PM
M-Audio Fast Track C600 - new interface nst7 Pro Tools 9 10 03-13-2012 09:57 AM
