Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 01-27-2017, 07:05 AM
gian.delgadoaspiazu gian.delgadoaspiazu is offline
Default Audiosuite Plugin not Affecting Master Volume
Hi everyone. I'm using MC 8.4 and I have the following problem, I hope somebody knows how to fix it. When I apply the Normalize plugin from the Audiosuite, it normalizes the clips that I'm working on; even the sound wave on the timeline changes; but the master volume remains the same. I'm trying to figure out if I'm doing something wrong or I changed something inadvertently.
I'd appreciate any input you can give me on this.
Gian Delgado-Aspiazu
Corner Brook, NL
Canada
Old 02-12-2017, 06:40 AM
Bookerv12 Bookerv12 is offline
Default Re: Audiosuite Plugin not Affecting Master Volume
Well,
All normalize does is bring the highest peak to zero.
If it's already near there, you're not going to get any real change in volume.
What are you trying to achieve with Normalize?
A volume boost?
Maybe you would have better luck with the track fader, compressor or peak limiter.
bookerv12
Volume automation no longer affecting playback in Pro Tools 8 LE supersteve114 Windows 7 06-10-2015 11:17 AM
Pan controls are affecting Volume Paul Marcellus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-02-2013 10:14 AM
affecting a volume curve to an audio file montreal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-19-2011 04:15 AM
Audiosuite Plugin preview volume? bryanbassett Pro Tools TDM Systems (Mac) 2 11-20-2008 07:29 AM
Master Fader Not Affecting Volume of Other Tracks Room335 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 02-15-2007 10:34 AM
