Mbox Pro 3rd "Hardware not connected" "Not Streaming"
Hello I`m new in this forum, I come to you with hope that you can help me with my interface that is driving me crazy.
History: One day I was recording late night, everything was normal and perfect. When I finished recording I went to sleep, the next day I would continue recording, I powered my computer and my interface and when I open the Mbox Core Audio Driver it said "Hardware not connected" "Not streaming" I thought that I would have made an error in the connection, so I restarted my computer but this problem continued. After some research I uninstalled the drivers and installed them again, but the problem continued, so I decided to buy another FireWire cable I decided to buy a "400 to 800" cable in order to avoid using the provided adapter, this cable didn`t fixed the problem. After this I decided to get in contact with Apple phone support, they made me reinstall the Mbox drivers, reinstall the opperating system, a reboot of my hard drive and every possible software issue, this didn`t fixed my problem so they told me to go to a Apple Store to see if there was a hardware issue with my computer, in the Apple Store they told me that there was no problem with the computer, they even replace my Thunderbolt to Firewire adapter. At this point I have bought more Firewire cables with no sign of connection between my computer and my interface and I have tried everything that you can imagine. Now my interface isn`t working I thought that with the new update of the drivers version 1.3.5 my interface would work. Interface behavior: When I power the interface it powers normal, the blue LED doesn`t make anything strange. With some Firewire cables in the Core Audio Drivers it says "Hardware not connected and Not Streaming" and with others cables it says "Hardware no connected and Not Set". Computer behavior: When I go to "System Preferences" - "System Information" in the part where it says "Firewire" theres and error that says "Firewire devices not listed". -Macbook Pro Retina 2105 2.7 GHz Intel Core i5 -OSX "El Capitan 10.11.6" -8 GB RAM. -Apple Thunderbolt to Firewire adapter, Firewire coverter and the cable that came in the interface"400 to 800" and Firewire cable 400 to 800. -Pro Tools 12 -Avid Mbox Pro 3rd generation firmware "1.3.5" Last edited by MK_Mow; 12-19-2016 at 11:21 PM. |
Re: Mbox Pro 3rd "Hardware not connected" "Not Streming"
Do you have another computer that you could test the Mbox on? Or could you take it to the Apple store and see if it is detected there? With all you've tried, it sounds like a hardware fault on the Mbox. You haven't hotplugged it have you?
Joel
Jam Space: HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Home: Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Rig: Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM |
No I haven´t hot connected it, I´ve tried to connected to another computer once but it was when drivers wheren`t updated to OSX 10.11.6 and it didn´t work so I don´t know if was the interface or the drivers.
The interface works fine, if I plug something it receives signal, but it´s not recognized by the the computer, with some Firewire cables in the Core Audio interface says "Not connected, Not Streaming" and with other cables says "Not connected, Not set". When it says "Not connected, Not set" I´ve tried this: http://avid.force.com/pkb/articles/e...s-the-firmware But it doesn´t make any difference. |
Re: Mbox Pro 3rd "Hardware not connected" "Not Streaming"
Testing it on another system can help diagnose if the firewire chip on the interface is still working. I'd still recommend that as the next diagnostic step.
Joel
Hi, I´m back to school so I had the chance to try my interface with other computers and the sad and bad news is that my interface is not recognized by any computer, so I´m afraid that my interface is damaged.
So I guess that there´s not much left to do |
Did you try a different cable?
Yes, I´ve tried different cables and it still not working
It does sound like a hardware fault with the Mbox. You could look at getting it repaired, but would probably be more economical to get a new, better interface.
Joel
Mbox Mini 3d Hardware Not Connected on Mac | YomghY | FireWire & USB Audio Interfaces (Mac) | 0 | 11-23-2015 07:15 AM |
MBox Mini Light down Hardware connected not streaming | maamarcal | Avid Scorch (iOS) Forum | 0 | 11-21-2015 02:52 PM |
Mbox Pro Hardware not Connected | raulgaviola | FireWire & USB Audio Interfaces (Win) | 2 | 09-14-2015 06:02 AM |
MBox Pro 3 Connected but not Streaming | b101 | FireWire & USB Audio Interfaces (Mac) | 3 | 01-14-2015 05:08 PM |
Mbox 3 - Hardware not connected - FIXED? | krabbencutter | FireWire & USB Audio Interfaces (Win) | 7 | 09-29-2014 06:59 PM |
