Windows 7 Memory Usage Cache Size
I have noticed protools will complain about using too much memory and occasionally crash when I set my Cache Size to 7GB or higher in Playback Engine. My system has 16 GB of memory and is usually hovering around 10-12GB or memory usage when this problem occurs. When I set my Cache Size to 6GB, the problem goes away. Anyone else experience this or know of a fix to allow protools to utilize more of my available memory?
Protools: 12.3.1 OS: Windows 7 CPU: i5 6500 Memory: 16GB DDR4 GPU: GTX 560 Ti OS Drive: 124GB Solid State Session Drive: Network Share (SMB) |
Re: Windows 7 Memory Usage Cache Size
I too have 16gb ram. You do not need to set the cache size that high. Only set it to cover the size of the session. Mine sits at 3gb which is usually more than enough. If you want to use 7gb you will have to up your ram to 24gb. Don't forget, your system and the programmes you are running require ram to function.
Dell Precision 490 Workstation, dual 4 core 5355 Xeon, 16gb Samsung DDR2 ECC Ram - Windows 7 Ultimate - Nvidia GTX 650 - 3 x Internal WD Blacks - PT 2018.3 - Digi 002R - Original Mackie HUI - 3 screens - JBL Monitoring. Dell XPS 8700 i7-4790 - 24gb RAM - Windows 10 - Nvidia GTX 1060 6GB with Studio driver 546.01 - 2 x Internal Samsung 860 EVO SSDs, and MSATA card - Davinci Resolve Studio 18.6.4 - 3 screens - Blackmagic Speed Editor - MK1 Presonus Faderport - Canon C100 mk2 - Atomos Ninja 2 - Zoom H2n |
Thanks for the response. Maybe I am not seeing correct memory usage from windows. I am seeing 8-6 gb of free memory reported by the resource monitor and assuming this is memory that can be used by protools.
Don't forget that the memory you allocate to the cache is not available for anything else. So if you make the cache 7gb you only have 9gb available to run PT, the computer o/s, plug-ins, and VIs, etc. So it soon gets eaten up. The 8-6gb you see in the resource monitor is whats available to run everything else, not just PT.
Solution to the error -9514 on Windows 8 (memory / cache / DAE buffer) | PySikE | Windows | 17 | 09-18-2022 06:04 AM |
Cache Size valuer? | AnderTools | Pro Tools 12 | 2 | 11-27-2016 06:41 PM |
HDD Cache size | JonnyGinese | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 12-14-2009 03:07 PM |
FW drive cache size | drmmrboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-02-2007 11:01 PM |
Cache size on new G4s and Pro Tools | jeronimo | Tips & Tricks | 0 | 08-02-2001 11:41 AM |
