New RME UFX Crackling Audio [SOLVED]
I installed an RME UFX to work with Pro Tools 12.4. Unfortunately, if I was playing down or recording into Pro Tools and had RME’s TotalMix or any other window open on the computer, there would be crackling in the audio as long as that window or any other windows remained open. This crackling would also be in any audio being recorded. And when resizing the TotalMix Window that was quite jittery. Here’s what I did to stop all that from happening:
I also copied my Pro Tools sessions off my Audio Drive, formatted my Audio Drive and then copied my Pro Tools sessions back to my Audio Drive (Avid recommends doing this rather than Defragmenting the Audio Drive). Not only has the crackling in the audio, whether playing back or being recorded, been stopped with any additional window or windows besides pro Tools being open, but also Pro Tools itself is now very stable and seems “snappier”. As well, sessions open and close (quite a bit) faster than before. Indeed the computer is faster outside of Pro Tools too. And now resizing the TotalMix Window is quite smooth. Hopefully some/all of the above may help someone else with the same or similar issues and/or graphic issues. As always, YMMV.
Take your projects to the next level with a non-union national read at reasonable rates Demos: brucehayward dot com SonoBus Source-Connect: brucehayward Options for Remote Direction Last edited by The Weed; 02-09-2016 at 09:29 AM. |
Re: New RME UFX Crackling Audio [SOLVED]
Which of these fixes do you think fixed the crackling?
The Weed said: "I also copied my Pro Tools sessions off my Audio Drive, formatted my Audio Drive and then copied my Pro Tools sessions back to my Audio Drive (Avid recommends doing this rather than Defragmenting the Audio Drive)."
I have never heard about not defragmenting the audio drive, and in fact have done so quite a few times with my rig (of course many of you guys keep up with the technical stuff more than I do). What are the potential pitfalls with defragging? With the method you described, wouldn't the fragmented files just be copied back to the formated drive? To answer digi98's question, I don't think it would be possible to know which step fixed the problem, unless a test of pro tools was done after each and every step.
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit. |
Cheers,
I know the conventional wisdom is to dedicate your soundcard to PT and not for windows, and I know that usually fixes "sample rate unavailable" issues with a lot of interfaces... But I encounter no such issue with my Babyface and UCX. I suspect the UFX will allow this with no issue as well, since it's the same driver.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB |
I've been trying to play Windows sound ( iTunes, YouTube tutorials) through a focusrite. Do all you Guys just give up on that or hang a 2nd pair of speakers off internal cards?
Definitely depends on the interface's driver and Focusrite's Windows drivers apparently, given some of the posts on the Forum, aren't spectacular. When I needed to replace my 002 Rack, I chose RME because of their rock solid drivers, both Mac and PC. I haven't tested whether I can use my UFX for Windows sounds/audio - and don't intend to. I have a Mackie Big Knob and route my onboard Realtek to it. This way I can use my mains for other sounds while still using Pro Tools and can record from my onboard Realtek into Pro Tools. And yes, AFAIK a lot of people use their onboard soundcard for Windows sounds/audio, either with a monitor controller or separate speakers.
YMMV Cheers, BTW, mesaone, I'm very happy with my UFX - clean and clear audio. The onboard Pres are, to my and other ears, an exact match for my Grace m101. Still updating the "home studio". Waiting for my TLM 49, changing a bit of the acoustic treatment in my DIY booth, will be getting some Primacoustic panels shortly and, when my current large project is completed, SourceConnect. Thanks for your recommendation for RME, much appreciated.
Focusrite interfaces hate that.
I don't remember what the exact issue was, but I disabled the internal soundcard completely (in the BIOS) to fix it.
Crackling audio fix pt 9.03 | motif6 | Windows | 5 | 08-15-2011 11:16 AM |
Crackling in Audio File | TCM | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 03-22-2011 03:10 AM |
Bizarre Audio Crackling... | yogi snaps | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-27-2009 07:35 AM |
Crackling Audio Through TDM Bus | Ray Campbell | Pro Tools TDM Systems (Mac) | 14 | 08-30-2004 02:57 PM |
Crackling Audio in Mix Plus | Boom Chic | Pro Tools TDM Systems (Mac) | 13 | 07-17-2002 11:57 AM |
