Old 11-11-2018, 01:11 PM
David Every David Every is offline
Default Pro Tools 2018.7 crashes when closing a session
Anyone else seeing this?
Old 11-11-2018, 01:25 PM
Default Re: Pro Tools 2018.7 crashes when closing a session
This generic issue has been discussed before on DUC. Most likely suspects are corrupt sessions or bad plugin. What have you changed recently? If there was a serious problem with 2018 I think we'd be hearing lots about it. Always possible that a specific plugin or two have been tripped up by something in a Pro Tools release and not many see it.. so important you troubleshoot for plugins if it's not a corrupt session.
Did you try trashing prefs? This happen on only one session? If so import that into a new session or use your last working backup. Otherwise plugins... see standard troubleshooting steps are under "help us help you" up top of each DUC web page.
Old 02-25-2019, 06:21 AM
hzd hzd is offline
Hi there.
I have protools crashing when closing. Also with no plug-ins at all.
I'll try to re-install and let you know.
eMachines M6811
1.25 GB RAM
Internal 5400 RPM 80 Gb
External 7200 RPM 160 Gb Maxtor Firewire
MBOX + 002R
ProTools LE 6.4
Ableton Live 5.2
Old 02-26-2019, 05:38 AM
junkgear's Avatar
junkgear junkgear is offline
Originally Posted by hzd View Post
Hi there.
If you are going to r-install, remove all of your plugins as well. With no plug-ins installed, run PT and see if it exits cleanly. If it does, then add back your plug-ins one by one until you find the one that is causing the hang on exit.
Will
System Details
Old 02-26-2019, 08:28 PM
I’ve been using 2018.12, issue seems to have gone away so far....
PTHD 9.0.6 crashes when closing session jrmintz macOS 0 04-06-2014 09:58 AM
PT 10.3.8 Crashes after closing session drvibb Pro Tools 10 2 03-20-2014 03:17 PM
PT HD 7.4 crashes when closing a session deardaddy Post - Surround - Video 10 05-21-2009 03:01 PM
Crashes when closing session Pro tools 7.0 Drive 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-07-2006 01:34 AM
pro tools app. crashes when closing session Blake Henderson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-27-2001 04:22 PM
