Unable to create Dae
What is the cause of this error? I've gotten it a few times already, had to restart my Mac in order to start up PT. Anyone now the reason and/or solution?
Re: Unable to create Dae
I have found the most common cause of this is some other application is using the hardware. Do you have the Digi-CoreAudio installed?
it's obvious if youhave iTunes open, but some surprising applications also grab the digi-hardware. I have had to quit PanoCalander, Gramotki, and other apps that I thought had nothing to do with audio. Try creating a new user and see if the problem persists. If so, you probably have some background utiltiy that is causing the problem. Good Luck, MC |
Yes, I have the Core Audio Driver an does happen when I use ITunes and sometimes with Peak. Sounds like a new bug.
were all hoping that this will be fixed in 6.1!!
Im getting tired of apps dying on me at start-up cause CoreAudio dont like to share:P |
And yes, it would be great if the drive could be used by multiple apps at the same time. |
Even when I close all apps. I still get the error and have to restart.
Unable to Create a DAE Deck - HELP!!! | mbdrums | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-14-2002 09:29 AM |
Unable to create DAE | Deric | Pro Tools TDM Systems (Mac) | 1 | 03-12-2002 09:43 AM |
Unable to create DAE | Deric | Pro Tools TDM Systems (Mac) | 1 | 03-12-2002 12:52 AM |
unable to create a DAE deck! | Bl1Nd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-24-2001 04:02 AM |
unable create dae deck | Bob DeMaa | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-12-2000 02:08 PM |
