Old 06-16-2017, 10:19 AM
charlzm charlzm is offline
Default Copy/paste time signature changes
I have a very complex piece of music I am trying to arrange. The time signature changes every bar or two.
I have been unable to duplicate or copy/paste the "meter" bar along with measures, tempo and audio.
The first time I tried, I got an error pop-up saying that the conductor was interfering with copying my time signature track but that everything else would be copied and pasted, which it was.
I tried again and this time I can't highlight any additional tracks other than audio. A third attempt resulted in not being able to duplicate anything.
I could copy and paste the audio then laboriously go through and duplicate about 50 bars of time signature changes, but there has to be an easier way to do this.
Old 06-16-2017, 03:41 PM
john1192 john1192 is offline
Default Re: Copy/paste time signature changes
I have been unable to duplicate or copy/paste the "meter" bar along with measures and audio.
sounds like a good Suggestion .. i just checked and you cannot Move / Duplicate / Copy any Meter changes .. only Delete using Option Key
can you do that in another DAW ?? are you coming from a different DAW and expect this behavior ?? curious !!
john
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 06-16-2017, 07:53 PM
I have only worked in Pro Tools for the last ten years. Many of the years were very light use, I'll admit.
Old 06-17-2017, 03:36 AM
remute remute is offline
With you mouse select the timeline/meter range you want to copy.
Hold Shift and tap the semicolon key repeatedly to then highlight all of the tracks you want to copy.
Duplicate away.
Old 06-17-2017, 05:56 AM
Duplicate away.
hi, what if you ONLY want to copy the Meter ??? not any tracks at all .. i could not get Shift to do anything .. please clarify
john
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 06-17-2017, 06:21 AM
Select the range on the Meter Ruler and either Duplicate or Copy/Paste
john
Old 06-17-2017, 07:02 AM
got it .. thx for the reply !!
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 06-18-2017, 09:18 AM
Duplicate away.
When following these exact directions in Windows, literally nothing pastes at all when I go "downstream" to the place I want to append the data. It works with duplicate, though, but that screws up the structure of the song.
Conductor is off, all tracks are ticks, absolute grid is on.
Old 06-18-2017, 09:58 AM
When you go "downstream" are you:
Selecting, in the Meter Ruler, the area to copy to
The using Shift+semicolon to also highlight the same area in the tracks below?
Old 06-18-2017, 10:09 AM
I have found a solution, though it is far from intuitive or simple.
  • Select where I want the repeated section to begin, then select all tracks and rulers, making sure to get everything to the right of this in the session, all the way to the end.
  • Duplicate.
  • Clear everything after the desired section.
Sure would be easier to do a simple copy and paste.
Copy... Paste... Paste... Paste...? accession 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 01-18-2022 04:18 PM
Copy/cut/paste and maintain time ilee Tips & Tricks 6 01-19-2014 02:37 AM
Copy works paste doesnt paste??? SoMedia Pro Tools M-Powered (Win) 12 01-04-2011 01:19 PM
Shuffle doesn't shift volumes - copy & paste doesn't copy automation marcnyc Pro Tools TDM Systems (Mac) 2 03-12-2010 12:46 AM
Time signatures copy and paste? broken81 Tips & Tricks 1 04-18-2008 01:21 PM
