Pro Tools 10 CPU usage help?
I'm running Pro Tools 10 with a Tascam US-600 interface.
During recording, playback, or even just record-armed and jamming, I noticed faint clicks and pops. I opened up my system usage window, and the cpu meter is bouncing like crazy between 10% and 20%. It clicks and pops every time it reaches 20%. I don't hear these clicks and pops while using the interface on garage band. I'm not sure how to fix. |
Re: Pro Tools 10 CPU usage help?
Usual cause is having the hardware buffer too low. Also having an even amount of processors set for playback so you need to set 1/3/5/7 etc in the playback engine. And certain native/RTAS plugins will cause the CPU to peak in relation to the above settings Chris
online usage and pro tools | jamiet | macOS | 1 | 06-25-2011 11:05 PM |
What would normal disk usage considered to be in the usage window? | Digitopian | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 09-08-2009 09:50 PM |
Why am i getting 100% CPU usage using pro tools 8? How do I fix it? | philipc | Post - Surround - Video | 5 | 07-11-2009 08:03 PM |
Ram usage with Mac OSX Pro Tools 7.2 | Digiboy cs1 | Tips & Tricks | 1 | 10-02-2006 06:25 PM |
CPU Usage 100% when running Pro Tools LE | Mason00 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 06-27-2005 12:50 PM |
