Old 05-12-2015, 10:10 PM
charlzm charlzm is offline
Default PT10_3_10 not reading iLok Hybrid authorization
I just upgraded to PT 10_3_10. When starting, a window appears telling me that no authorization for my copy of Hybrid can be found on the installed iLok.
However, when I start the iLok License Manager, Hybrid appears and the iLok shows that Hybrid is authorized.
Also, when I go to
https://www.avid.com/subscriptions
I can see that I have a license for Hybrid.
Can someone tell me what I am doing wrong (or what Pro Tools is doing wrong if it's not me)?
Old 05-12-2015, 10:55 PM
jeffro's Avatar
jeffro jeffro is offline
Default Re: PT10_3_10 not reading iLok Hybrid authorization
Can you please check the version of your Hybrid plug-in? There was a 1.6 upgrade that required a new license (named Hybrid 1.6 instead of just Hybrid). If this is the case (you have a license named "Hybrid"), you can remove the v1.6 plug-in and install 1.5.x. See this page for downloads if needed.
linkedin
Old 05-16-2015, 09:15 AM
Default
Yes, it is 1.6 I have installed. Will try 1.5 and see how that works. Thanks for the tip!
AIR Hybrid 3.0 - PT Says Authorization Is Missing/Damaged epu Virtual Instruments 6 07-31-2014 10:55 AM
Hybrid is asking for iLok Authorization after updating to Pro Tools 10.3.x MErnst Virtual Instruments 33 05-24-2014 08:47 AM
error: missing ilok authorization for pro tools... please insert the necessary ilok. Witold.B Pro Tools Express on Mac OS X 1 04-21-2014 03:59 AM
Hybrid Authorization ChristianAllanRamirez RTAS & TDM Plug-ins 7 07-31-2013 12:38 AM
Transfuser and Hybrid authorization issue Gearaddictz Virtual Instruments 3 02-11-2011 12:50 PM
