Active or passive ??
Again sorry this isnt protools , but i need to know .
Alesis actives £269 alesies passive with power amp RA300 , costs £375 . people tell me to get passives and a power amp , why ??? Whats better , i think id rather go for actives . advise me if im wrong !
Pro tools 001 user on PC . |
Re: Active or passive ??
Passives and a pwr amp give you options. You can use the same pwr amp with many different monitors. You can use the monitors with many different amps. With actives you have no options. The monitors and amps are one unit.
Another thing to consider is that if you have passives and a separate amp, if the amp goes bad you don't lose your monitors, you just use a different amp. With actives you lose both if either goes bad. I already had an amp lying around so I got passives and saved the money I didn't need to spend on the amp. If I would have started with no amp I'd have probably gone for actives since it seems to be cheaper than going the separate components route. Get whichever you like the sound of best. If they sound the same, get the less expensive option. If you want the option of using different amps with different monitors then get the separate components. Mike
-- Mike - HP Spectre x360 Convertible 14t-ea100 - 2.9 GHz (5.0 Max Turbo) i7-1195G7 32GB RAM, OLED 3k x 2k, Iris Xe Onboard Graphics - Windows 11 - PT 2021.12 - PreSonus Quantum 2 - PreSonus Studio 24c - Mackie Onyx 1640i - Samsung T3 and T5 SSDs - Various USB2/3 and Firewire HDDs |
Ilok Passive NOT Active | RussUK | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-22-2008 11:41 AM |
Monitors; active or passive? | Gothboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-20-2007 08:26 AM |
Active vs Passive Monitors | tabnetic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 10-25-2005 02:00 PM |
Passive or Active D.I. | carnology | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-10-2005 09:02 PM |
Passive/Active | vicwind | General Discussion | 0 | 11-25-2003 08:43 PM |
