Old 08-27-2017, 05:01 PM
yorgo yorgo is offline
Default Crossfade issue
Hey guy... Been having this problem for a while and I'm not sure I understand. ...
Basically when I try to do a crossfade between to clips, it will always say"invalid audio amount"and tells me to adjust the bounds and then it will place the crossfade at the beginning of the second clip.
I can't do a crossfade between to clips.
I was wondering if there is a parameter I need to change? Thanks
Sent from my SM-N910W8 using Tapatalk
Pro tools 11.3, Windows 7 Premium,
Desktop i5 4670 3.4ghz 16G ram quad core
Old 08-29-2017, 08:34 AM
Drew Mazurek's Avatar
Default Re: Crossfade issue
Turn on Quickpunch so that PT is recording in the background thereby giving you "handles" for fades.
www.drewmazurek.com
Old 08-29-2017, 09:02 AM
Ok, thanks for the work around. Any idea on what could be causing that?
Old 08-29-2017, 09:07 AM
It's not a workaround. You're getting that dialog because there isn't audio beyond the clip boundary to be used for the fade. It's physics!!
www.drewmazurek.com
Old 08-29-2017, 09:12 AM
Aaaahhhh. Ok. Sorry. Misunderstood. Thanks. I will try it.
Crossfade issue Majita Pro Tools 10 5 04-16-2012 06:01 AM
Need help on a crossfade djak24k Pro Tools M-Powered (Win) 3 04-16-2009 03:29 PM
Crossfade issue? nortstudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-22-2008 04:57 PM
