Old 01-16-2018, 07:39 PM
[email protected] pqlior@mac.com is offline
Default Random softkey functions don't work
I made a few custom softkeys and not all functions work.
One (screenshot attached) is supposed to go to top of mixer (does that) then switch to edit window (does that) then go to top (does NOT do that), select my mix range (does that) then start recording (does NOT do that)
Another thing that doesn't work- switching ALL tracks' automation to read. I programmed a EUCON-OS modifier option then EUCON auto read and it does NOTHING.
Thoughts?
File Type: jpg Screen Shot 2018-01-16 at 7.38.10 PM.jpg (47.3 KB, 0 views)
Lior
HD Native * PT 2018.12 * OS X 10.13.6 * MacPro 12 Core * 2.4GHz 24GB Ram * 2XUAD2 Octo * Waves Platinum * Lexicon PCM Native Bundle * Sound Toys Bundle* AutoTune8 * NI Komplete11 * BFD3 * Synthogy Ivory II* Vienna Ensemble Pro * Spectrasonics * Slate trigger2 *xFer records * Softube * Vienna Ensemble * DMG Expurgate * Massey DRT2 *
iPad Air/Avid control * EuCon 18.3.0.217 *
Old 01-17-2018, 06:55 AM
Anthony_Anz Anthony_Anz is offline
Default Re: Random softkey functions don't work
Thoughts?
that "Record" eucon command probably just sets the record button. you have to start the transport (play) to actually record, no?
Old 01-17-2018, 07:20 AM
You are correct. Took a while to figure that out, but now works.
What about set all to auto read? (option modifier doesn't work for me in any scenario. (not in Eucon OS modifiers and not in Keyboard modifiers)
Also the hold checkbox in key commands is always grayed out...
Lior
Old 01-17-2018, 11:27 AM
I'm not in front of a surface to test this myself but try this..
Global -- Do To All
Automation -- Modes -- Read
** Update ** try this too. from the dock manual. page 28.
3) To change the automation mode on all tracks, hold Option (Mac) or Alt (Windows) while pressing SHIFT(Control Surface) + REC/A.
Old 01-22-2018, 12:57 PM
Global -- Do To All
If I wanted to hold modifier keys on the computer keyboard, I wouldn't buy a controller. They offer modifier keys in manual but they don't work...
Lior
Old 01-23-2018, 07:43 AM
Assign a softkey to the EUCON Commands I mentioned in my previous post. It works perfectly.
Global -- Do To All
New to artist control- not all functions work [email protected] Artist Series 0 12-18-2017 07:50 PM
Avid Control / eucon 3.5 / cubase 9 pro - Two functions on one softkey Feinbeat Artist Series 4 05-02-2017 05:50 AM
Zoom Functions SoftKey rcutz Avid S4/S6 2 04-26-2016 07:23 PM
Transport Functions C600 doesn't work hollow Pro Tools 11 1 08-16-2013 07:12 AM
ProControl & 6.4 or 6.7 & ALL functions work?????? A Spooner ProControl, Control|24, Command|8 2 03-20-2005 12:39 PM
