Problems with pt11 and plugins aax
Excuse me for my english, i´m spanish. I have pt11 and i work on win 8 64 bits. I have installed waves 9,13 , izotope rx3 adavanced and i cant see them in pt 11. i have opened pt 10 and there i can see theme. This is driving me crazy. Any body knows the solution? Thanks for all |
Re: Problems with pt11 and plugins aax
v9r13 is 32 bit only, so you won't see them in Pro Tools 11 only Pro Tools 10. You need to download and install Waves AAX-64 bit to see them in Pro Tools 11. You also need v9r13 installed before installing the AAX-64 Waves plug-ins, so you're half-way there.
Cheers,
Thank you very much.
Do you know whats the problem whith izotope rx3, i have the same problem, i can´t see them |
If it's not AAX-64 you won't see it in Pro Tools 11.
Cheers,
Maybe Im wrong but I installed Waves Complete 9r13 a couple of days ago when they told me that Waves was now AXX 64 compliant. After installing v 9r13 you have to download and install a small file called "WaveShell-AAX.exe". This makes the plugins visible in PT 11.02. Check you waves account....good luck!
Hi
I tried all the ways to install it in pt 11 , but did not appear in the list I don't know why ???????!!!!!!!! |
Plugins available in PT11, but not 10 | tha]-[acksaw | Pro Tools 10 | 4 | 12-25-2013 08:16 AM |
PT11.1 ADC with UAD plugins | 6lovemusic | Pro Tools 11 | 6 | 12-24-2013 03:00 PM |
PT11 & Digirack Plugins | ianbee | Pro Tools 11 | 3 | 12-17-2013 07:46 PM |
PT11 Plugins? | zixis9 | Pro Tools 11 | 6 | 06-09-2013 07:02 PM |
New instrument plugins for PT11? | JCcares | Virtual Instruments | 7 | 04-12-2013 04:00 PM |
