Can\'t separate s/pdif output from Analog outs
Hi All,
As the subject says, I Can't separate s/pdif output from Analog outs. Trying to use an external device for Reverbs, but it wants to send the Analog mix there too. I have unchecked s/pdif mirroring in the hardware setup, but it still won't separate the outputs. Interestingly, the manual says to go to "Playback Engine, select other options, and deselect mirroring" there. However, this "other options" button doesn't appear here, but the mirroing button does appear in hardware setup. In I/O setup, I get separate inputs for S/PDIF, but not separate outputs. They appear together with the analog outs. Any Ideas? Thanks Digi 001 G4 1000mhz (upgraded from 400) Os 10.3.4 PT 6.4 |
Analog and S/PDIF output at the same time | Chuck1073 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 02-06-2012 03:27 PM |
MBox 2 can't have 4 separate outs? | EricWillhelm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-20-2008 09:24 AM |
S/PDIF or analog output? | stainless | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 05-01-2007 12:13 PM |
002 Core Audio Q: mirroring analog to s/pdif outs | OpusFluke | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-27-2003 08:07 PM |
S/PDIF, Analog outs and phase (Guitar) | bassmac | Tips & Tricks | 1 | 07-22-2002 12:28 AM |
