Endless closing session window?
all of a sudden my work session takes about 5-10 Minutes to close while PT shows this window (attached picture). Wastes a lot of time when I need to look into a different session from time to time. At the moment I can only force-quit to respond to quick questions. Is there a cure for this? I already deleted DBs, prefs and the other standard procedures without success. Thanks! Frank
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Re: Endless closing session window?
We have the same problem with bigger sessions incl. field recorder workflows for a while now. Haven't found any solution other than force quitting.
Mac Pro 3,7 GHz Quad-Core Intel Xeon E5 Mac OS 10.15.7 ProTools Ultimate 2020.11 Video Slave 4.3.477 |
Thanks for confirming. The odd thing is that it started just a week ago but the session size hasn't significantly changed. Yes, it's big but it has been the whole time even when closing didn't hang.
I tried de-activating field recorder on all tracks but it's still the same. weird...I'll just keep force-quitting. Since the session is saved at that point I think it should do no harm. Frank.
Had it couple of times in somewhat heavy sessions.
Since upgrading to 64 GB ram, I haven't encountered this issue.
2023.12 Ultimate / Mac Pro (Late 2013) / 6 core 3.5GHz / 64Gb / OSX 12.7.2 / MTRX Studio / 2xArtist Mix / PT|Control / Aja T-Tap |
Thanks, I've got 48GB RAM and when the session is open I still have 20GB available according to Activity Monitor and it has always been inn that area even when the session closed just normally.
Endless, endless glitches trying to import audio. Better solution? | imjtblanton | Pro Tools 2018 | 5 | 06-13-2018 05:29 PM |
PT Crash After Closing Boom, Save Session and Close Session | Hannibal Lecter | Pro Tools 12 | 5 | 02-02-2017 02:23 PM |
session seems endless? | gamblor | Pro Tools 10 | 9 | 03-30-2013 10:53 PM |
Session layout not being remembered after closing/reopening a session/Pro Tools! | DJ Hellfire | Pro Tools 10 | 1 | 12-23-2011 12:05 AM |
Closing the Send window. | zerocide | ICON & C|24 | 0 | 05-02-2008 09:25 AM |
