monitoring the LED lights on the digi002...how??
i've lately been learning about unity gain.
now, i know u can meter each track with the LED lights on the 002, but since there are no numbers...how do i know if i'm peaking at 0? i mean...cuz i need to have the slider on 0 and have the signal peak at 0 on the LED lights right? but how would i know if there's no numbers? where would "0" be on the LED lights? where would ANY number be associated to on the LED lights??? _chris |
Re: monitoring the LED lights on the digi002...how??
JoyMODE101,
This same question was brought up recently..(search) You are in the digital domain..between the AD and the DA converters. You are reading DFS scale. When you "Peak" it means there isn't any more bits available in the system to convert. Not good. hope this helps a bit.. happy tooling,
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
hhmmmm.....
i just got more confused now. lol what should i search for exactly? "led lights"??? -chris |
I have an 002 and never look at the LED's at all. I use the "meters" in the edit window. Just the way I like to work.
cuz i'm using the digi002 as standalone. i guess i'm not understanding UNITY GAIN. can someone explain this to me or link me somewhere to know how i can do this, preferably when using a digi002 please? i'm just using the 002 as a mixer with my MPC2000XL. would i set up UNITY GAIN in this situation? is it standard to set up unity gain in EVERY situation??? thanx so much _chris |
Sorry, that was in protools as I have never used standalone mode. Ditto on unity gain-set the fader at -0-, but for live, set it where it sounds right. Use the "meters" to set the input gain. You have gain knobs on the first 4 inputs. Inputs 5-8 have a switch on the back for -10 or +4. Use -10 for things like acoustics and keybaords. Use +4 for line level stuff like a POD or a pro DAT machine. If the -10 setting is too hot and you max the meters, select the +4 position. You want the meters to peak in the upper third or around the 3 o'clock position since they are around the pan encoder knobs.
THAT'S what i was wondering about. lol thanx so much guys. so...i should set the tracks (in this case it's inputs 5-8) to 0 and get their meter(s) to peak at the 3' o clock position right? THIS is unity gain, right? _chris |
ok... since i'm using my digi002 as a standalone mixer live, i send main 1 and main 2 outputs to the house. what should i be monitoring so that the house gets a good level? i just wanna make sure, but...do i go by the master faders??? do i also make sure to get the MASTER FADER LEVELS at 0 with the LEDs peaking at 3 o'clock as well??? is this the correct way to go? if not, what is?? please let me know. thank you |
Digi002 - Monitoring out without Pro Tools launched | Room335 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 04-30-2007 06:06 AM |
Monitoring your input during playback with DIGI002 | stevethrewup | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-15-2007 04:08 PM |
Low latency monitoring with Digi002 | yvon.k | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-08-2005 01:22 AM |
Fader lights on Digi002 blink sometimes? Defective | Johnny916 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 05-21-2004 04:35 AM |
RTAS effects monitoring ? digi002 | Digi002Fla | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 04-16-2003 10:30 AM |
