Mono / Stereo Mode in plugins
if im working with mono tracks and i process the track with a plugin in "stereo mode" , what happens? does it acknowledge this, or does it still remain mono? is there any negative results by doing this? sometimes i forget to change it mono mode when using the speed plugin......thats why.
Re: Mono / Stereo Mode in plugins
look at the track after you inserted the plugin. If you still have one meter, its all mono. If it has 2 meters, then the mono-signal is processed as a stereo-signal (dual mono to be exact), and the output then indeed is stereo. Try it with a reverb or delay....
What's that? - That's the machine that goes "pling". Bastiaan |
Mult-mono vs Stereo Plugins | JLEpperson | Tips & Tricks | 4 | 08-10-2010 05:48 PM |
Stereo Aux vs Mono Aux and Turning that Mono into stereo via a stereo Plugin | JesseF | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 02-14-2010 09:01 AM |
Stereo linking mono plugins? | Che_Guitarra | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-31-2008 07:45 AM |
Help using 2 mono plugins to make stereo? | broken81 | Tips & Tricks | 3 | 02-13-2008 01:58 AM |
Problem with 2 mono plugins on a stereo track | Andres Gonzalez | Pro Tools TDM Systems (Win) | 2 | 03-28-2007 08:32 AM |
