How do you uninstall the Eleven Rack Driver?
I know that I have an old interface, the DIGI 003, and it is not showing up as playback engine. I saw that a fix for this is to actually uninstall the seemingly unrelated Eleven Rack Driver.
Maybe the answer is to uninstall Pro Tools and then reinstall without the Rack option? Perplexed that driver installers are not in the application manager... |
Re: Eleven Rack Driver Uninstall
If you read the thread above more carefully it describes using the driver uninstaller. Have you done that? I am not sure uninstalling the Eleven Rack driver will help you however. Where exactly did you see that advice? Please provide a web link. You might be better off trouble shooting your Digi 003 setup/driver install. Does the 003 show up in Core Audio? What exact macOS version are you running and what exact 003 driver are you trying to install? The most common issue with driver installs on recent versions of macOS is lack of driver signage. Did you get an error in macOS Security & Privacy>General Preferences that you need to approve the install? And in the worse case any driver on a Mac can be manually uninstalled, the kext (driver) itself removed from /System/Library/Extensions folder (device disconnected, move the kext elsewhere and reboot) and any Preferences Panes deleted by hand. But be careful hacking away on stuff. And there can be other minor stuff left behind but usually getting rid of those two things will remove the drivers for any practical purpose. But again, I be surprised if any of that is needed here. Last edited by Darryl Ramm; 10-22-2018 at 07:43 PM. |
UPDATED:
Mac OSX 10.13.6 iMac (Retina 5K, 27-inch, Late 2014) 4 GHz Intel Core i7 32 GB 1600 MHz DDR3 AMD Radeon R9 M295X 4096 MB Pro Tools 2018.10.0 I did finally see that you had to find the standalone installer on the Avid site and then download it and do a deinstall. I'll also trouble shoot the DIGI 003 installer. DIGI 003 does not show up in Audio MIDI setup in the Audio devices window. Let me explain why I involved the Eleven Rack... about 4-5 months ago, I re-installed my entire system onto this iMac. I then noticed the Dgigi 003 didn't show up. I dug and dug and finally found one person that had posted somewhere about the Eleven Rack needing to be uninstalled, I remember doing that. And lo, and behold, I was able to see the DIGI 003 and use it to record through an XLR input. Today, I was updating the application manager and I noticed the checkboxes for auto install and auto update. I checked that, since it also notified me that Pro Tools needed to be updated. Of course it automatically installed the Eleven Rack. And now the DIGI 003 is gone... I'll go over the steps you listed and look up anyone else who might be have been in the same boat. I'll also probably just buy a new interface in the next few weeks. |
I got it back! But of course it could've been the deinstallation or it could have been someone tugged on the old firewire connection, and I simply pushed it back in. I'll test it by re-installing the Eleven Rack.
Eleven Rack is a hardware interface, and I don't see that listed in any of your info. If you don't have an Eleven Rack in this system then don't install the Eleven Rack Driver or Eleven Rack Editor. Note that the Eleven Rack Drivers include uninstallers in case you need to run one.
• linkedin •
Cool. If you get stuck again and the 003 is connected run "kextstat | grep 003" (trying to remember what the 003 kext reports itself as, but I think that "003" will find it). You want to see the kext driver loaded and being reported by kextstat when the device is connected, even if it the device does not show up anywhere else. That not happening is a (very) sick driver install or hardware problem.
Eleven Rack Driver Uninstall | Tonetek | Eleven Rack | 7 | 01-17-2016 06:50 AM |
How Do You Manually Uninstall Eleven Rack | JoeGuitarist | Eleven Rack | 0 | 12-05-2015 08:15 AM |
How to Uninstall Digidesign Eleven Rack from OS Preferences | wdjudd | macOS | 1 | 08-20-2013 08:18 AM |
Eleven Rack Beta 1.04 Driver for OSX | Deny | Eleven Rack | 9 | 08-25-2011 01:25 PM |
