Buffer problem - cannot start
Hey, so after my first launch of PT I changed the ASIO driver to my internal audio card (Creative SBZ Asio), PT has restarted and then a popup window says: "Your audio device is configured with an unsupported audio buffer size. Please select on of the following buffer sizes in the device control panel, if available: 32, 64, ...".
The problem is, I can't change the buffer in Creative Asio (I'm mainly working in Samplitude Pro X3 which doesn't care about this, so I wasn't prepared for it). On this popup window if i click anything (like Ok, More info or Exit) it closes the program, so I cannot say to PT to use a different ASIO. And I can't change the buffer. So I cannot start the program. Any suggestions? |
Re: Buffer problem - cannot start
OS?
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro PT 2023.3 Studio through an A&H Qu-32 |
Windows 10 64bit
And my hardware: CPU: Intel Core i7-4770 MB: Gigabyte H87-HD3 GPU: nVidia GeForce GTX 770 RAM: 4x Kingston HyperX Fury 8 GB DDR3 1600 MHz Sound: Creative Sound Blaster Z |
Try ASIO4ALL if you don't have an interface. Better yet, get an interface.
Of course I have tried installing ASIO4ALL but since I can't choose in PT to use this ASIO (because it quits after the popup window no matter what I click as I have written), I can't help it.
And I have an interface, even thou only Behringer UMC404HD. But again, I can't choose to use UMC ASIO as default, because I can't get into the options in PT. |
Try holding down the "N" key while starting PT. This should bring up the Playback dialogue so you can choose an interface.
Yes! Thanks, that's the solution. :)
Buffer Error at the start of every session (Structure LE) | The Dougfather | Virtual Instruments | 3 | 06-05-2008 06:01 PM |
Problem on start up | Gaz103 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-29-2006 11:18 AM |
Problem with start up | onezero | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-27-2001 07:23 AM |
DAE start problem (& others) | wilseven | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-29-2000 07:59 AM |
start up problem | Hendrik | Pro Tools TDM Systems (Mac) | 0 | 04-20-2000 01:45 PM |
