Digi002 RACKMOUNT -or- CONTROL SURFACE?
I'm desperately wanting to get my hands on an 002 but I'm a little confused as to what I need. Will I need both the rack mount & the control surface or can I get away with just having one or the other? Is there a huge advantage to having the control surface over the rack mount? Thanks! Tommy |
Re: Digi002 RACKMOUNT -or- CONTROL SURFACE?
You can get away with just the 002R and then, should you so wish you can buy a control surface but it's not essential. Pro Tools supports the hui protocol for third party control surfaces, i actually use the behringer BCF2000 with my 002R and it's a great little device, works perfectly with Pro Tools, theres also the command 8 by Digi which will give you tighter integration but it's way more expensive. You might also wanna check pro tools m-powered with the project mix i/o for a real bargain.
Cheers
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D --- iCON Photography |
I like the 002R just because I can mount it with my motu 2408 and my mic pre with spidf out. I found a great surface made by Radikal Technologies. It is the Sac 2.2. It not only controls P.T. but many other daw's as well as some midi units as well. It is not as full function as the 002 but it is almost as good. If you are lucky you can find one on ebay for $500 or so. I really like mine. Good luck.
BARKING DOG STUDIOS MAC G5 DUO CORE MacBook Pro 2.66 8GB. 002 R 002 MOTU 2408 MK.3 PRESONUS DIGIMAX MIDAS 320 Tascam DM 24 Ramsa DM 7 EVENT 20/20 Way to much stuff |
Axiom Pro 61 vs Digi002 as control surface | trebot000 | Getting Started | 8 | 03-07-2014 06:47 PM |
Is my Digi002 Control Surface Broken? | Dee Mac | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-31-2005 07:49 PM |
Can I use DIGI002 as a simple control surface? | Hendrix_forever | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-24-2005 03:09 AM |
Digi002 control surface owners PLEASE HELP | Chaotic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 04-19-2004 08:29 AM |
Digi002 Control Surface Guide | fmckinnon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 03-15-2003 12:09 AM |
