Old 07-30-2015, 08:38 AM
ArfurGee ArfurGee is offline
Default PT11 HD, Graphics crash when moving clips
I haven't seen this mentioned anywhere else for a while, but is anyone else having graphics crashes when moving clips up and down tracks?
I'm in constant danger of dropping clips over each other as I move them vertically up or down the screen. As I scroll or move up whilst holding clips, the tracks appear to be blank and/or the the tracks themselves lose the tramlines. It's a basic problem but insanely annoying!
I'm running a new Mac pro (AMD FirePro D500 3072 MB) with PT11 HD.
Anyone?!
http://protools.ideascale.com/a/dtd/247307-3779
Old 07-30-2015, 04:34 PM
Chief Technician's Avatar
Question Re: PT11 HD, Graphics crash when moving clips
Which version of 11? Which OS? How many monitors?
Old 07-31-2015, 06:48 AM
Default Re: PT11 HD, Graphics crash when moving clips
PT11.3.1 HD, Yosemite 10.10.4, I have 3 screens running.
Old 07-31-2015, 11:51 AM
Is each screen on a separate Thunderbolt bus?
Old 08-01-2015, 01:54 AM
Ah no they weren't, I'll try separating them and let you know.
Old 08-01-2015, 02:05 AM
OK, all on different busses now but still the same problem.
Old 08-01-2015, 06:47 PM
Please keep in mind that v11.3.1 was not qualified for OS X v10.10.4.
If you go to ~/Library/Logs/CrashReporter/, do you see any logs for Pro Tools? You may not, as Avid has eschewed OS X's crash reporter for their own crash reporting mechanism that uses Google's BreakPad. It's worth looking though, since Avid's crash logs, if present, are encrypted and unreadable by people with the decryption key.
Old 08-02-2015, 02:20 AM
Anyone?!
Yes, I get this all the time too. Since updating to 10.10.3 (from 10.8.5). When I move chips the graphic sometimes goes bananas and it *seems* like your are dropping things onto empty tracks but when you do you realize that they were the wrong tracks and also that you wiped something out that you could not see.
Seen this on many different installations of 11.3.1 on 10.10.3 on both 5,1 MPs and Cylinder Macs.
Guess it's a bug.
Frank.
PTHDn 2019.6 (OSX10.14.4), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM
Old 08-02-2015, 08:49 AM
Have either of you logged this at protools.ideascale.com?
Old 08-03-2015, 06:56 AM
No not yet, will do though.
Actually it turns out this happening to few other people that I'm working with at the moment, this is obviously a bigger problem than I thought, it's becoming increasingly annoying.
moving clips fmilian Pro Tools 11 6 05-08-2015 05:11 AM
moving all the clips! TakenGrace Pro Tools 11 6 06-21-2014 01:07 PM
PT11 loses automation when moving clips Frank Kruse Pro Tools 11 4 02-20-2014 12:54 PM
GUI graphics bug after moving regions! crizdee Pro Tools TDM Systems (Mac) 0 01-22-2011 02:55 PM
PT7 Waveform graphics moving bug? Vinylizor Pro Tools TDM Systems (Mac) 17 05-02-2006 09:35 AM
