Old 01-23-2018, 08:05 AM
Anthony_Anz Anthony_Anz is offline
Default Assigning Multiple Tracks to a Group?
Anybody know of a way (using the dock or PT Control) to assign multiple tracks to a group?
I've tried...
1) Selecting all of the tracks I want to add to an existing group
2) pressing "Do To Sel"
3) navigating over to the Groups Tile
4) Press "In" in the group slot I want to add the tracks to
but only the attentioned track will be added to the group.
Old 01-27-2018, 02:40 AM
Maro Records's Avatar
Maro Records Maro Records is offline
Default Re: Assigning Multiple Tracks to a Group?
I afraid it's impossible.
I tried the same but with failure.
Maro,
http://www.marorecords.com
Old 01-27-2018, 10:10 AM
BScout BScout is offline
Closest you'll get is:
From iPad
Select Tracks
Modify Groups
Select Group
click with mouse "Use Track Selection from Mix/Edit Window: Add" on screen. (or Replace.) There's probably a way to add that last click to a user tile/softkey
Old 01-28-2018, 07:35 PM
From iPad
Select Tracks
Modify Groups
Select Group
Cool. I'll give it a try! There should def. Be a more direct way to do it.
Assigning multiple tracks to a bus DonaldM Tips & Tricks 7 11-07-2015 03:13 PM
Bussing and/or Assigning multiple tracks to same output negate OTB Summing? Myles83 macOS 1 07-23-2013 06:18 PM
How do I record enable multiple instrument tracks in a group? grateful macOS 5 03-23-2013 07:12 AM
Comping multiple tracks that are in a group problem no-xplode macOS 1 01-25-2012 02:09 AM
strip silence treats multiple tracks as a group mike connelly Tips & Tricks 1 01-17-2002 07:11 AM
