Protools HD11 - Coreaudio - negative H/W Insert Offset required?
Hey Chaps!
I am just setting up my system and have hit a hurdle when it comes to the I/O menu. Specifically the H/W Delay Offsets. I have followed the instructions in the manual about determining the amount of hardware offset needed... but it appears as though I need a negative value??? If you have a look at this - http://www.soundonsound.com/sos/feb1...es/pt-0213.htm There are images that show how the protools mixer is set up, and the resulting tracks. The problem I have currently is that the newly recorded track (track 2 in the SOS article) is 200 samples AHEAD of track 1. If I enter the value in milliseconds (about 5.something), then repeat the process recording the output of channel 1 to a new track - the resulting waveform is ANOTHER 200 odd samples ahead again. What the fugg is going on? Why is my audio time traveling?
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command. |
Re: Protools HD11 - Coreaudio - negative H/W Insert Offset required?
Nothing?
Nadda? No one else experiencing this problem?
Are you running plugins on Master? I believe PDC is still not supported on Master.
Hey Matt!
Thanks for the reply. There is nothing on the master at all. The only 'plugin' is one instance of external effect as per the instructions in the Protools manual. I upgraded from HD 11.1.2 to HD 11.2.1. There was a noticeable improvement running exactly the same test. The offset dropped to just 7 samples! But it still means the resulting audio is being delay compensated too much! I have run the same test in HD10 and I get exactly the same result - the audio being recorded to track 2 is 7 samples too early! If you have a look at the screenshot of the protools mixer of HD11, you will notice that channel 1 is being delay compensated by 1240 samples. This happens as soon as I add the external effect to the channel. What I don't understand is, why is it doing this? Is 1240 samples the absolute value of ADC needed by HDx/HDn to make hardware inserts phase accurate? If it is, why isn't it bypassed when running coreaudio? This bug is effectively making the I/O plugin delay menu absolutely useless. It is set to 0.00ms in this test. If I add any other value to it, the audio on track 2 moves even further in front of the audio on track 1.
What's your interface? Are you running HDN or HDX?
The problem doesn't exist with HDN. It occurs when running a Lynx Aurora 16 via USB and coreaudio.
Nobody has anything to add on this??
Surely this indicates a bug somewhere? Either in Protools ADC or the latency being reported by the Lynx USB card?
Thanks Christopher
Its much worse than you think, Chris.
I have asked this same question 5 times over 4 forums in the last 12 days. So far the only response it has garnered from an affiliate of either company involved is a reprimand for the efforts I am going to to try and actually get a response to the question. While the TOS have been duly noted, and your role and commitment to the forum respected, your reply has only fuelled my frustration. Where can I find someone whom will address my question, Chris?
Anyway, if you don't get any help here you might have to buy a ASC from Avid and call them to help you out but making several threads is nit the answer, Best Regards Christopher
Delay Compensation, User offset negative | HiLoc | Pro Tools TDM Systems (Mac) | 4 | 04-03-2010 01:18 AM |
Mbox2 noise floor has large negative DC-offset | DRP | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-04-2010 06:14 AM |
Negative Video Sync Offset??? | admix | Post - Surround - Video | 3 | 05-15-2008 10:34 AM |
Negative "User offset" ADC numbers possible? | Tim R. | Pro Tools TDM Systems (Mac) | 1 | 06-19-2007 03:14 PM |
negative feet.frames offset? is it even possible? | sndgeek | Post - Surround - Video | 7 | 06-20-2004 11:27 PM |
