Problems crossfading multiple regions in Pro Tools 10
Hey All!
Have a little problem that's driving me a bit nuts and cutting into my workflow a bit. I can't seem to crossfade multiple regions at once. When I highlight the sections where I want a fade and press F to fade, it only creates fade ins and outs as opposed to crossfading. When press CTRL F to bring up the fade menu, it does not work either. What am I doing wrong? Pictures for reference attached. Highlighted region - http://imgur.com/TJdPxZ4 Result of pressing F - http://imgur.com/cLjkdva Any help you can provide would be much appreciated! |
Re: Problems crossfading multiple regions in Pro Tools 10
Are you sure there's enough underlying audio to make the fade? IOW, those clips aren't at the file boundaries are they?
Yes, there is plenty of audio to work with on both sides!
Thanks for responding. |
select regions, press cmd-f, uncheck "new fade ins and outs" and adjust all the other settings.
I think you also need to make sure you select more than 2 separations. If you only select 2 it does in/out only in pt10. (I think)
Sent from my iPhone using Tapatalk |
It was solved on gearslutz. https://www.gearslutz.com/board/post...ools-10-a.html
Basically : the WHOLE clip on the left side and the WHOLE clip on the right side need to be selected.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
Crossfading multiple tracks in PT 9 | Iscariot13 | Pro Tools 9 | 3 | 12-21-2011 02:57 PM |
Crossfading between regions when comping | DonaldM | Tips & Tricks | 10 | 12-28-2010 08:22 PM |
Pro Tools 7.4 problems dragging or copying multiple regions | Dustin Mosley | Pro Tools TDM Systems (Mac) | 23 | 02-23-2008 12:47 PM |
Crossfading stereo regions gives strange results | ibvee | Pro Tools M-Powered (Win) | 1 | 12-19-2007 05:33 AM |
Crossfading problems | joel4283 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-21-2001 11:20 AM |
